ACE SSL terminate not working ... please help
Hello, I configured cisco ace 4710 with ssl-proxy and it is not working, but http://10.1.40.2 and http://10.1.40.3 is OK.  When i put https://10.1.41.20 the output is: "There is a problem with this website's security certificate", so i click in "Continue to this website (not recommended)" and the ace dont balance the output show error "Internet Explorer cannot display the webpage".
The configuration:
ace-demo/Admin# sh run
Generating configuration....
boot system image:c4710ace-mz.A3_2_4.bin
boot system image:c4710ace-mz.A3_2_1.bin
login timeout 0
hostname ace-demo
interface gigabitEthernet 1/1
  channel-group 1
  no shutdown
interface gigabitEthernet 1/2
  channel-group 1
  no shutdown
interface gigabitEthernet 1/3
  channel-group 1
  no shutdown
interface gigabitEthernet 1/4
  channel-group 1
  no shutdown
interface port-channel 1
  switchport trunk allowed vlan 400-401,450
  no shutdown
crypto csr-params testparams
  country PE
  state Lima
  locality Lima
  organization-name TI
  organization-unit TI
  common-name www.yyy.com
  serial-number 1000
access-list anyone line 8 extended permit ip any any
access-list anyone line 16 extended permit icmp any any
parameter-map type ssl sslparams
  cipher RSA_WITH_RC4_128_MD5
  version SSL3
rserver host rsrv1
  ip address 10.1.40.2
  inservice
rserver host rsrv2
  ip address 10.1.40.3
  inservice
serverfarm host farm-demo
  rserver rsrv1
    inservice
  rserver rsrv2
    inservice
serverfarm host site-A
  rserver rsrv1
    inservice
serverfarm host site-B
  rserver rsrv2
    inservice
ssl-proxy service testssl
  key testkey.key
  cert testcert.pem
  ssl advanced-options sslparams
class-map type management match-any MGMT
  2 match protocol icmp any
  3 match protocol http any
  4 match protocol https any
  5 match protocol snmp any
  6 match protocol telnet any
  7 match protocol ssh any
class-map match-any VIP
  6 match virtual-address 10.1.41.10 any
class-map type generic match-any WAN-site-A
  2 match source-address 192.168.10.106 255.255.255.255
  3 match source-address 192.168.10.125 255.255.255.255
class-map type generic match-any WAN-site-B
  2 match source-address 192.168.10.96 255.255.255.255
  3 match source-address 192.168.10.93 255.255.255.255
class-map type management match-any icmp
class-map match-any vip-ssl-10.1.41.20
  2 match virtual-address 10.1.41.20 tcp eq https
policy-map type management first-match ICMP
  class icmp
    permit
policy-map type management first-match MGMT
  class MGMT
    permit
policy-map type loadbalance first-match vip-ssl-10.1.41.20
  class class-default
    serverfarm farm-demo
policy-map type loadbalance generic first-match lb-server
  class WAN-site-A
    serverfarm site-A
  class WAN-site-B
    serverfarm site-B
  class class-default
policy-map multi-match client-side
  class VIP
    loadbalance vip inservice
    loadbalance policy lb-server
policy-map multi-match lb-vip
  class vip-ssl-10.1.41.20
    loadbalance policy vip-ssl-10.1.41.20
    loadbalance vip icmp-reply
    ssl-proxy server testssl
interface vlan 400
  description side-server
  ip address 10.1.40.1 255.255.255.0
  access-group input anyone
  service-policy input ICMP
  no shutdown
interface vlan 401
  description side-client
  ip address 10.1.41.1 255.255.255.0
  access-group output anyone
  service-policy input client-side
  service-policy input lb-vip
  no shutdown
interface vlan 450
  description mgmt
  ip address 10.1.45.1 255.255.255.0
  service-policy input MGMT
  no shutdown
ip route 192.168.10.0 255.255.255.0 10.1.45.10
And the proof:
ace-demo/Admin# sh serverfarm farm-demo
serverfarm     : farm-demo, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: rsrv1
       10.1.40.2:0           8      OPERATIONAL  0          25         19
   rserver: rsrv2
       10.1.40.3:0           8      OPERATIONAL  0          23         18
ace-demo/Admin# sh crypto files
Filename                                 File  File    Expor      Key/
                                         Size  Type    table      Cert
admin                                    887   PEM     Yes         KEY
testcert.pem                             709   PEM     Yes        CERT
testkey.key                              497   PEM     Yes         KEY
ace-demo/Admin#
ace-demo/Admin# sh service-policy lb-vip class-map vip-ssl-10.1.41.20
Status     : ACTIVE
Interface: vlan 1 401
  service-policy: lb-vip
    class: vip-ssl-10.1.41.20
      ssl-proxy server: testssl
      loadbalance:
        L7 loadbalance policy: vip-ssl-10.1.41.20
        VIP ICMP Reply       : ENABLED
        VIP State: INSERVICE
        Persistence Rebalance: DISABLED
        curr conns       : 0         , hit count        : 38
        dropped conns    : 18
        client pkt count : 159       , client byte count: 12576
        server pkt count : 16        , server byte count: 640
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
      compression:
        bytes_in  : 0
        bytes_out : 0
        Compression ratio : 0.00%
in other time:
Status     : ACTIVE
      loadbalance:
        curr conns       : 0         , hit count        : 170
        dropped conns    : 89
        client pkt count : 703       , client byte count: 60089
        server pkt count : 85        , server byte count: 3400
      compression:
        bytes_in  : 0
        bytes_out : 0
ace-demo/Admin#
ace-demo/Admin# sh stats crypto server
+---- Crypto server termination statistics ----+
SSLv3 negotiated protocol:                       43
TLSv1 negotiated protocol:                        0
SSLv3 full handshakes:                           37
SSLv3 resumed handshakes:                         0
SSLv3 rehandshakes:                               0
TLSv1 full handshakes:                            0
TLSv1 resumed handshakes:                         0
TLSv1 rehandshakes:                               0
SSLv3 handshake failures:                         6
SSLv3 failures during data phase:                 0
TLSv1 handshake failures:                         0
TLSv1 failures during data phase:                 0
Handshake Timeouts:                               0
total transactions:                               0
SSLv3 active connections:                         0
SSLv3 connections in handshake phase:             0
SSLv3 conns in renegotiation phase:               0
SSLv3 connections in data phase:                  0
TLSv1 active connections:                         0
TLSv1 connections in handshake phase:             0
TLSv1 conns in renegotiation phase:               0
TLSv1 connections in data phase:                  0
+------- Crypto server alert statistics -------+
SSL alert CLOSE_NOTIFY rcvd:                      0
SSL alert UNEXPECTED_MSG rcvd:                    0
SSL alert BAD_RECORD_MAC rcvd:                    0
SSL alert DECRYPTION_FAILED rcvd:                 0
SSL alert RECORD_OVERFLOW rcvd:                   0
SSL alert DECOMPRESSION_FAILED rcvd:              0
SSL alert HANDSHAKE_FAILED rcvd:                  0
SSL alert NO_CERTIFICATE rcvd:                    0
SSL alert BAD_CERTIFICATE rcvd:                   0
SSL alert UNSUPPORTED_CERTIFICATE rcvd:           0
SSL alert CERTIFICATE_REVOKED rcvd:               0
SSL alert CERTIFICATE_EXPIRED rcvd:               0
SSL alert CERTIFICATE_UNKNOWN rcvd:               6
SSL alert ILLEGAL_PARAMETER rcvd:                 0
SSL alert UNKNOWN_CA rcvd:                        0
SSL alert ACCESS_DENIED rcvd:                     0
SSL alert DECODE_ERROR rcvd:                      0
SSL alert DECRYPT_ERROR rcvd:                     0
SSL alert EXPORT_RESTRICTION rcvd:                0
SSL alert PROTOCOL_VERSION rcvd:                  0
SSL alert INSUFFICIENT_SECURITY rcvd:             0
SSL alert INTERNAL_ERROR rcvd:                    0
SSL alert USER_CANCELED rcvd:                     0
SSL alert NO_RENEGOTIATION rcvd:                  0
SSL alert CLOSE_NOTIFY sent:                      0
SSL alert UNEXPECTED_MSG sent:                    0
SSL alert BAD_RECORD_MAC sent:                    0
SSL alert DECRYPTION_FAILED sent:                 0
SSL alert RECORD_OVERFLOW sent:                   0
SSL alert DECOMPRESSION_FAILED sent:              0
SSL alert HANDSHAKE_FAILED sent:                  0
SSL alert NO_CERTIFICATE sent:                    0
SSL alert BAD_CERTIFICATE sent:                   0
SSL alert UNSUPPORTED_CERTIFICATE sent:           0
SSL alert CERTIFICATE_REVOKED sent:               0
SSL alert CERTIFICATE_EXPIRED sent:               0
SSL alert CERTIFICATE_UNKNOWN sent:               0
SSL alert ILLEGAL_PARAMETER sent:                 0
SSL alert UNKNOWN_CA sent:                        0
SSL alert ACCESS_DENIED sent:                     0
SSL alert DECODE_ERROR sent:                      0
SSL alert DECRYPT_ERROR sent:                     0
SSL alert EXPORT_RESTRICTION sent:                0
SSL alert PROTOCOL_VERSION sent:                 47
SSL alert INSUFFICIENT_SECURITY sent:             0
SSL alert INTERNAL_ERROR sent:                    0
SSL alert USER_CANCELED sent:                     0
SSL alert NO_RENEGOTIATION sent:                  0
+--- Crypto server authentication statistics ---+
Total SSL client authentications:                 0
Failed SSL client authentications:                0
SSL client authentication cache hits:             0
SSL static CRL lookups:                           0
SSL best effort CRL lookups:                      0
SSL CRL lookup cache hits:                        0
SSL revoked certificates:                         0
Total SSL server authentications:                 0
Failed SSL server authentications:                0
+------- Crypto server cipher statistics -------+
Cipher sslv3_rsa_rc4_128_md5:                    43
Cipher sslv3_rsa_rc4_128_sha:                     0
Cipher sslv3_rsa_des_cbc_sha:                     0
Cipher sslv3_rsa_3des_ede_cbc_sha:                0
Cipher sslv3_rsa_exp_rc4_40_md5:                  0
Cipher sslv3_rsa_exp_des40_cbc_sha:               0
Cipher sslv3_rsa_exp1024_rc4_56_md5:              0
Cipher sslv3_rsa_exp1024_des_cbc_sha:             0
Cipher sslv3_rsa_exp1024_rc4_56_sha:              0
Cipher sslv3_rsa_aes_128_cbc_sha:                 0
Cipher sslv3_rsa_aes_256_cbc_sha:                 0
Cipher tlsv1_rsa_rc4_128_md5:                     0
Cipher tlsv1_rsa_rc4_128_sha:                     0
Cipher tlsv1_rsa_des_cbc_sha:                     0
Cipher tlsv1_rsa_3des_ede_cbc_sha:                0
Cipher tlsv1_rsa_exp_rc4_40_md5:                  0
Cipher tlsv1_rsa_exp_des40_cbc_sha:               0
Cipher tlsv1_rsa_exp1024_rc4_56_md5:              0
Cipher tlsv1_rsa_exp1024_des_cbc_sha:             0
Cipher tlsv1_rsa_exp1024_rc4_56_sha:              0
Cipher tlsv1_rsa_aes_128_cbc_sha:                 0
Cipher tlsv1_rsa_aes_256_cbc_sha:                 0
ace-demo/Admin# crypto verify testkey.key testcert.pem
Keypair in testkey.key matches certificate in testcert.pem.
ace-demo/Admin#
ace-demo/Admin#  sh conn
total current connections : 0
conn-id    np dir proto vlan source                destination           state
pablo.nxh
Level 3
Level 3
Hello Alvaro,
The issue here is that your config is missing the clear text port the ACE should use to send the traffic to the backend servers; in this case port 80.
Remove the rservers from the SF "farm-demo" and then configure them back like this:
  rserver rsrv1 80
    inservice
  rserver rsrv2 80
    inservice
That should do the trick =)
__ __
Pablo
pablo.nxh
Level 3
Level 3
Hello Alvaro,
  rserver rsrv1 80
    inservice
  rserver rsrv2 80
    inservice
__ __
Pablo
You are excellent!!! thank you now is working!!
