ACE ssl termination issue
hedyeh razazan
Community Member
I have two ACE 4710 which configured az virtual context and active/active, i configured ssl termination and Load balancing.
  load balancong works fine but with ssl termination, after the main page (web server login page)  display and i enter username and password, error page display, in the ACE ,"show conn" command  shows connection established,
can any one help me plz?
i create certificate with openssl, with these command:
openssl genrsa –out key.pem 1024
openssl req -new -x509 -nodes -sha1 -days 365  -key key.pem –out cert.pem
my configuration:
access-list everyone line 8 extended permit ip any any
access-list everyone line 16 extended permit icmp any any
rserver host NS1
  ip address 192.168.1.11
  inservice
rserver host NS2
  ip address 192.168.1.12
  inservice
ssl-proxy service proxy-1
  key key.pem
cert cert.pem
serverfarm host NS
  rserver NS1 80
    inservice
  rserver NS2 80
    inservice
class-map match-all NS-vip
  match virtual-address 192.168.215.138 tcp eq https
policy-map type management first-match remote-access
  class class-default
    permit
policy-map type loadbalance http first-match slb
  class class-default
    serverfarm NS
policy-map multi-match NS-vips
  class NS-vip
    loadbalance vip inservice
    loadbalance policy slb
    ssl-proxy server proxy-1
interface vlan 75
  ip address 192.168.215.132 255.255.255.224
  access-group input everyone
  service-policy input NS-vips
  no shutdown
Jorge Bejarano
Level 10
Level 10
Hedyeh,
Have you tried to bypass the ACE? What results do you have if you do that?
What do you see with #show service-policy class-map detail
Please apply the following change:
parameter-map type http http-parameterTAC  ---> This parameter should be applied in multimatch policy.
  case-insensitive
  persistence-rebalance
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
policy-map multi-match MULTI-TAC
    class VIP-TAC
    loadbalance policy VIP-TAC-L7
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 112
    appl-parameter http advanced-options http-parameterTAC ---> applied  parameter
    ssl-proxy server VIP-TAC-SSL
Additionally, you might be missing the intermediate certificate, then maybe you can try to use a chaingroup with the intermediate certificate:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_0/command/reference/chaingrp.html
Hope this helps!
Jorge
Cesar Roque
Level 8
Level 8
Hi Hedyeh,
Do you have simultaneous captures on both sides showing this issue?
Have you tried with stickiness configured?
Cesar R
ANS Team
--------------------- Cesar R ANS Team
