ACE - TCP Options for Proxy-Connections
dknoezinger
Hi all,
I have the issue that my ACE does not seem to allow tcp options with L7 proxied connections to the servers. For the client side connection I see the TCP option timestamp for example, but unfortunately the ACE itself does not put the timestamp option into its own TCP connection to the rserver. A 'parameter-map type connection' does only seem to have an effect on L4 connections, not proxied ones. Does anybody know a way how to tell the ACE to have e.g. a timestamp option in the TCP connection to the server as part of a L7 loadbalancing?
Any help is highly appreciated!
Daniel
Gilles Dufour
Daniel,
we do not support timestamp at L7.
I think we only support window scaling.
Gilles.
