ACE Web GUI Interesting Problem
thefindjack
Level 4
Level 4
I have a very strange issue with the ACE web GUI interface. I have 2 ACE's that are in Active/Standby setup with a floating management IP address for each context. Now when I try to login to the Web interface with the Floating Mgmt. IP address for one of my contexts it always takes me to the Admin context and not the one I am trying to hit. I did some testing and I found it does this with every context when you try to login to the Web interface using the floating IP address. If I use one of the real IP's of an individual ACE I am able to get logged into the correct context. Has anybody else run into this? Is there something I can do to fix it? Also I noticed that when you login to the web interface using that same floating IP address it always passes RADIUS requests as the Admin context IP address as well.
Gilles Dufour
I don't see this problem with version A3(2.x)
This was fixed with CSCso98451
G.
