ACE without keyboard response from serial console
Martin Kyrc
Level 3
Level 3
hello,
I have a problem with connection to ACE module. I'm direct connected to console port on the ACE module. ACE boots without problem, but I can't send to console no keyboard input (break sequence, login/password, etc.). my serial console is configured normaly (9600,8,n,1). The same problem is sessioning to module from msfc.
this is a new (changed) ACE module.
btw: in other chassis is serial console access working
any ideas?
martin
Gilles Dufour
The console chip could be broken.
If this is a new one, just get a replacement from the TAC.
Gilles.
