ACE20 and TLSv1.0 extensions problem
ciscocsoc
Level 4
Level 4
I have a problem with an ACE20 running software version A2(2.3) [build 3.0(0)A2(2.3)].
We have a simple load-balancing arrangement for two Apache webservers. All we do is pass HTTP and HTTPS traffic through to one of two servers. we don't do SSL termination or initiation on the ACE - just passthrough.
We now have a requirement to support connections that only use TLSv1.0 with no fallback to SSLv3. If I use IE8 the connection works. If I use IE9 or FF19 then the connection fails. I've traced this to the use of TLS extensions in the ClientHello packet - which came after the TLSv1.0 RFC. IE8 doesn't send extensions whereas the other browsers do.  I can replicate the problem with the OpenSSL s_client application. What surprises me is that the ACE checks the structure of the TLS negotiation even though I'm not asking it to make decisions about it. I can see why this would be done as a security feature if the ACE implemented a strict RFC2246-compliant server - the extensions having bee added post-RFC.
Is there any way to tell the ACE to forward SSL packets and not worry too much about the contents? I've checked all the Release notes and can't find any relevant caveats.
Thank you
Cathy
12 Replies 12
ajayku2
I believe following defect matches your symptoms. This is not fixed in ACE20 but you can disable SSL rehandshake.
CSCtn00305            Bug Details
SSL rehandshake does not follow RFC 5746
Symptom:
ACE does not send server hello extensions for Secure Rehandshake.
Conditions:
The SSL proxy has the following parameter map applied.
parameter-map type ssl rehand
rehandshake enabled
Workaround:
Do not use rehandshake.
The same defect has been carried over and got fixed in ACE30. ( CSCtq48352 )
regards,
Ajay Kumar
Hi Ajay,
Thank you.  I don't think that is the problem as I'm not using the SSL proxy feature - just forwarding packets to the server. As far as I can tell, the ClientHello packet never reaches the server.
Kind Regards
Cathy
Sorry I missed that part and you are right. Just for testing can you disable Normalization and check if that fix the issue.
Also share the config.
regards,
Ajay Kumar
Hi Ajay,
Disabling normalization made no difference. I thought it might help, but I think it only looks at the gross structure of the packets and doesn't worry about RFC2246 compliance.
The relevant parts of the configuration are shown below:
rserver host web-web1
  ip address a.b.c.d
  inservice
rserver host web-web2
  ip address a.b.c.e
  inservice
serverfarm host FARM-web2
  rserver web-web1
    inservice
  rserver web-web2
    inservice
sticky ip-netmask 255.255.255.255 address source FARM-web2-Sticky
  timeout 99
  replicate sticky
  serverfarm FARM-web2 backup FARM-sorry
class-map match-any L4VIPCLASS
  2 match virtual-address x.y.z.t tcp eq www
  3 match virtual-address x.y.z.t tcp eq https
  6 match virtual-address x.y.z.t tcp eq 81
policy-map type loadbalance first-match LB-POLICY
  class class-default
    sticky-serverfarm FARM-web2-Sticky
policy-map multi-match L4POLICY
  class L4VIPCLASS
    loadbalance vip inservice
    loadbalance policy LB-POLICY
    loadbalance vip icmp-reply active
    loadbalance vip advertise
service-policy input L4POLICY
As you see, the configuration is about as simple as it can be.
Kind Regards
Cathy
Hi Cathy,
Can you get a Tengig capture of the ACE module and replicate this
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar,
I didn't get a 10Gig capture - but I did a cpature from the context on both interfaces. I hope that is sufficient. There is a bit of chaff at the start of CAP-SSLv3.pcap when I fumbled the URL (htttps - Doh!).
IP Addresses:
128.243.101.53 - My PC.
128.243.80.167 - The VIP.
128.243.80.182 - The rserver that was chosen in the serverfarm.
Kind Regards
Cathy
Cathy,
You took the capture from the ACE itself?
I agree with César it would have been better with a TenGig capture instead.
Jorge
Hi Jorge, César,
I've attached a capture of an attempted TLSv1-only session from the ACE 10Gig interface as requested.
Thank you
Cathy
samir ahmed
Hi Cathy,
You must be use action-list type modify command to achive the desired Result.
action-list type modify http Rewrite_Redirects
    ssl url rewrite location ".*"
policy-map type loadbalance first-match bsm-ssl-back
  class class-default
    serverfarm
    action Rewrite_Redirects
this should work if vip are accessible via https.
Thanks for looking at this.
I can' t see why this would work. I'm not doing SSL termination and we are failing in the SSL handshake before we even start to worry about web traffic. There isn't a redirection that we need to rewrite as far as I can see. Maybe I'm being a bit dense here - could you clarify why the change should work.
Thank you
Cathy
Hi Cathy,
If you look at the packet capture I see that the server is not replying with server certificate instead it is sending FIN
Look at the screenshot:
That is what ACE forward to client. To me it looks like server does not support TLS.
Also look at the below screenshot it shows ACE forward the communication properly to server.
regards,
Ajay Kumar
Hi Ajay,
Odd. This is now starting to look like a server-side issue. I'll investigate further at this end.
Thank you
Cathy
