ACE20 Module lost config after reboot.
fariha zain
Hi Expert,
My ACE module rebooted itself and after the reboot it lost all the config and it has been booted with factory default setting.
Software
  system:    Version A2(3.3) [build 3.0(0)A2(3.3)]
  system image file: [LCP] disk0:c6ace-t1k9-mz.A2_3_3.bin
And When I execute tac-pac command, the following output is printed out:
ACE-Admin#`show accounting log all`
*** Context 0: cmd exec error ***
I would like to know the reason for the same. Is this due to firmware bug? or with the Hardware?
I am bit dissatisfied that all of my config vanished without any reason after the reboot of ACE.
Please can someone help?
Fari
Daniel Arrondo Ostiz
Hi Fari,
The "*** Context 0: cmd exec error ***" most of the time points towards a hardware failure, so, I would strongly recommend you to open a TAC service request to have this investigated in more detail.
Daniel
Hi Daniel,
I have already replaced the ACE module and this is the new module which went down today.
So should I again raise the New RMA? Is this any reason of the module restart itself and loose all of its config?
REgards
Fari
Hi Fari,
I didn't tell you to raise a new RMA, I told you to open a TAC case to have it investigated further. We will then see if an RMA is needed or not.
Daniel
