ACE20 Module, webservices and regular expressions.
Fernando Bello
Hello All,
I am trying to loadbalance requests for webservices in a serverfarm. But for some reason, ACE20 module y not making matches on the requests.
We have a serverfarm Prod1 with 2 real servers and another serverfarm named WSDL with other 2 real servers.
The idea is the following, if we receive the following string, /App.WebService, the ACE should redirect it to serverfarm Prod1, but if it receives /App.WebService?wsdl, it should be redirected to WSDL.
Request with string /App.WebService --------------> ServerFarm Prod1
Request with string /App.WebService?wsdl -----> ServerFarm WSDL
We use regular expression in L7 class maps to make the loadbalance to happen.
class-map type http loadbalance match-all APP.WEBSERVICES-L7-SLB
  2 match http url /App\.WebService\?wsdl
class-map type http loadbalance match-all APP-L7-SLB
policy-map type loadbalance first-match L7_SLB-POLICY
  class APP.WEBSERVICES-L7-SLB
    serverfarm WSDL
  class APP-L7-SLB
    serverfarm Prod1
  class L4_SLB_DATAPOWER(9050)
    loadbalance vip inservice
    loadbalance policy L7_SLB-POLICY
    loadbalance vip icmp-reply
    appl-parameter http advanced-options HTTP_PARAM
    ssl-proxy server wildcard.test.org
    connection advanced-options TCP_PARAM
But the ACE20 Module seems to be removing the ?wsdl from the URL and only the class-map called APP-L7-SLB is being matched.
Any comments or suggestions on why this could be happening?
Thanks in advance,
Fernando
Kanwaljeet Singh
Hi Fernando,
Do you have "parsing non-strict" in http parameter map? If not, kindly apply that and check if that makes a difference.
Kanwal
Hello Kanwal,
I've added the parsing non-strict to the parameter-map but the problem is still happening. The ACE seems to be removing the ?WSDL from the URL, therefore the loadbalance is not happening.
Thanks anyway for the quick response.
Fernando
Hello Kanwal and all,
Finally, after reading and reading I found a fix to this problem. Seems that the HTTP protocol uses the question mark (?) character as a delimiter for data appended to the URL. So, if you get the following:
www.test1.org/App.WebService?wsdl
If you configured a L7 class map to parse the URL, it will only parse until the question mark (?).
So you need to create a PARAMETER-MAP changing the URL delimiter start. Here is an example:
parameter-map type http HTTP_PARAMETER_MAP_WSDL
  persistence-rebalance strict
  set secondary-cookie-delimiters ;!@?
  set secondary-cookie-start ;
I used the semicolon ( ; ) as delimiter.
Hope this helps.
Fernando
