ACE20 Module with Exchange 2010 Configuration
b.youssef
Hello all,
I have deployed the following configuration for Exchange 2010, if all services are up on the two servers it functions good but if a service goes down on one server (especially outlook) some clients are disconnected (stickiness) ...
Stickiness is needed for all services by ip source sticky and by coockies for OWA.
Because all services are on the same server (ip address) the configured sticky causes problems !!! when a service is down the ACE usually forwards  requests to it !!!! Any help please.
Configuration :
XXXXX-ACE1/CTXT-EXCHANGE(config)# do sh run
Generating configuration....
access-list BPDU-Allow ethertype permit bpdu
access-list EXCH-LB line 10 extended permit ip any any
probe http HTTP-GET
  interval 10
  passdetect interval 10
  request method get url /iisstart.htm
  expect status 200 202
probe icmp PING
  interval 3
probe tcp abport
  port 7575
  interval 2
  faildetect 2
  passdetect count 1
  connection term forced
probe tcp epmap
  port 135
  interval 2
  faildetect 2
  passdetect count 1
probe tcp http
  interval 2
  passdetect interval 2
  passdetect count 1
probe http http-probe
  interval 60
  passdetect interval 60
  passdetect count 2
  request method get url /exchweb/bin/auth/owalogon.asp
  expect status 400 404
probe tcp https
  port 443
  interval 2
  passdetect count 1
probe http https-probe
  interval 60
  passdetect count 2
  request method get url /owa/auth/login.aspx
probe tcp imap
  port 143
  interval 2
  passdetect count 1
probe tcp imaps
  port 993
  interval 2
  passdetect count 1
probe udp ipsec
  port 500
  interval 2
  passdetect count 1
probe icmp ping
  interval 2
  passdetect count 1
probe tcp pop3
  port 110
  interval 2
  passdetect count 1
probe tcp pop3s
  port 995
  interval 2
  passdetect count 1
probe tcp rpcport
  port 7576
  interval 2
  faildetect 2
  passdetect count 5
probe tcp smtp
  port 25
  interval 2
  passdetect count 1
rserver host CAS1
  ip address 172.22.101.74
  inservice
rserver host CAS2
  ip address 172.22.101.76
  inservice
rserver host HUB1
  ip address 172.22.101.75
  inservice
rserver host HUB2
  ip address 172.22.101.77
  inservice
rserver redirect RPC-REDIRECT
rserver redirect SSLREDIRECT
  webhost-redirection https://mail.tunisiana.com/owa 302
  inservice
serverfarm host CAS-Outlook
  probe PING
  probe abport
  probe epmap
  probe rpcport
  fail-on-all
  rserver CAS1 135
    inservice
  rserver CAS1 7575
    inservice
  rserver CAS1 7576
    inservice
  rserver CAS2 135
    inservice
  rserver CAS2 7575
    inservice
  rserver CAS2 7576
    inservice
serverfarm host CAS-http
  probe HTTP-GET
  probe PING
  rserver CAS1 80
    inservice
  rserver CAS2 80
    inservice
serverfarm host CAS-https
  probe https
  probe ping
  rserver CAS1 443
    inservice
  rserver CAS2 443
    inservice
serverfarm host CAS-imap
  probe PING
  probe imap
  rserver CAS1 143
    inservice
  rserver CAS2 143
    inservice
serverfarm host CAS-imaps
  probe imaps
  probe ping
  rserver CAS1 993
    inservice
  rserver CAS2 993
    inservice
serverfarm host CAS-ipsec
  probe ipsec
  probe ping
  rserver CAS1
    inservice
  rserver CAS2
    inservice
serverfarm host CAS-pop3
  probe ping
  probe pop3
  rserver CAS1 110
    inservice
  rserver CAS2 110
    inservice
serverfarm host CAS-pop3s
  probe ping
  probe pop3s
  rserver CAS1 995
    inservice
  rserver CAS2 995
    inservice
serverfarm host CAS-smtp
  probe ping
  probe smtp
  fail-on-all
  rserver CAS1 25
    inservice
  rserver CAS2 25
    inservice
serverfarm host HUB
  probe ping
  probe smtp
  rserver HUB1
    inservice
  rserver HUB2
    inservice
serverfarm redirect RPC-REDIRECT
serverfarm redirect SSLREDIRECT
  rserver SSLREDIRECT
    inservice
parameter-map type http STICKY
  persistence-rebalance
parameter-map type connection TCP_IDLE_30min
  set timeout inactivity 1800
sticky ip-netmask 255.255.255.255 address source HUB-ST
  timeout 30
  replicate sticky
  serverfarm HUB
sticky ip-netmask 255.255.255.255 address source CAS-http-ST
  timeout 30
  replicate sticky
  serverfarm CAS-http
sticky ip-netmask 255.255.255.255 address source CAS-https-ST
  timeout 30
  replicate sticky
  serverfarm CAS-https
sticky ip-netmask 255.255.255.255 address source CAS-imap-ST
  timeout 30
  replicate sticky
  serverfarm CAS-imap
sticky ip-netmask 255.255.255.255 address source CAS-imaps-ST
  timeout 30
  replicate sticky
  serverfarm CAS-imaps
sticky ip-netmask 255.255.255.255 address source CAS-smtp-ST
  timeout 30
  replicate sticky
  serverfarm CAS-smtp
sticky ip-netmask 255.255.255.255 address source CAS-pop3-ST
  timeout 30
  replicate sticky
  serverfarm CAS-pop3
sticky ip-netmask 255.255.255.255 address source CAS-pop3s-ST
  timeout 30
  replicate sticky
  serverfarm CAS-pop3s
sticky ip-netmask 255.255.255.255 address source CAS-ipsec-ST
  timeout 30
  replicate sticky
  serverfarm CAS-ipsec
sticky ip-netmask 255.255.255.255 address source CAS-Outlook-ST
  timeout 30
  replicate sticky
  serverfarm CAS-Outlook
sticky http-cookie sessionid exchange-sticky-sessionid-grp
  timeout 20
  serverfarm CAS-http
sticky http-cookie cookie OWA-STICKY
  cookie insert browser-expire
  timeout 60
  replicate sticky
  serverfarm CAS-http
sticky http-header Authorization CAS-RPC-HTTP
  serverfarm CAS-http
class-map match-any CAS-OUTL-MAPI-VIP
  2 match virtual-address 172.22.101.69 tcp any
class-map match-any CAS-Outlook-VIP
  2 match virtual-address 172.22.101.69 tcp eq 135
  3 match virtual-address 172.22.101.69 tcp eq 7575
  4 match virtual-address 172.22.101.69 tcp eq 7576
class-map match-any CAS-http-VIP
  2 match virtual-address 172.22.101.69 tcp eq www
class-map match-any CAS-https-VIP
  2 match virtual-address 172.22.101.69 tcp eq https
class-map match-any CAS-imap-VIP
  2 match virtual-address 172.22.101.69 tcp eq 143
class-map match-any CAS-imaps-VIP
  2 match virtual-address 172.22.101.69 tcp eq 993
class-map match-any CAS-ipsec-VIP
  2 match virtual-address 172.22.101.69 udp eq 500
class-map match-any CAS-pop3-VIP
  2 match virtual-address 172.22.101.69 tcp eq pop3
class-map match-any CAS-pop3s-VIP
  2 match virtual-address 172.22.101.69 tcp eq 995
class-map match-any CAS-smtp-VIP
  2 match virtual-address 172.22.101.69 tcp eq smtp
class-map match-all CAS_SERVERS
  2 match source-address 172.22.101.64 255.255.255.192
class-map match-any HUB-VIP
  2 match virtual-address 172.22.101.80 any
class-map match-all HUB_SERVERS
class-map match-all OWA-OUTLOOKANYWHERE-SSL
class-map match-all OWA-SSL-CM
class-map match-all OWAREDIRECT
class-map type management match-any REMOTE-MGT
  201 match protocol snmp any
  202 match protocol http any
  203 match protocol https any
  204 match protocol icmp any
  205 match protocol ssh any
  206 match protocol telnet any
policy-map type management first-match REMOTE-MGT
  class REMOTE-MGT
    permit
policy-map type loadbalance first-match CAS-Outlook-policy
  class class-default
    sticky-serverfarm CAS-Outlook-ST
policy-map type loadbalance first-match CAS-http-policy
  class class-default
    sticky-serverfarm CAS-http-ST
policy-map type loadbalance first-match CAS-https-policy
  class class-default
    sticky-serverfarm CAS-https-ST
policy-map type loadbalance first-match CAS-imap-policy
  class class-default
    sticky-serverfarm CAS-imap-ST
policy-map type loadbalance first-match CAS-imaps-policy
  class class-default
    sticky-serverfarm CAS-imaps-ST
policy-map type loadbalance first-match CAS-ipsec-policy
  class class-default
policy-map type loadbalance first-match CAS-pop3-policy
  class class-default
    sticky-serverfarm CAS-pop3-ST
policy-map type loadbalance first-match CAS-pop3s-policy
  class class-default
    sticky-serverfarm CAS-pop3s-ST
policy-map type loadbalance first-match CAS-smtp-policy
  class class-default
    serverfarm CAS-smtp
policy-map type loadbalance first-match HUB-policy
  class class-default
    serverfarm HUB
policy-map type loadbalance first-match OWA-OUTLOOKANYWHERE
  match OUTLOOK_ANYWHERE http header User-Agent header-value "MSRPC"
policy-map type loadbalance first-match OWA-SSL-PM
  class class-default
    sticky-serverfarm OWA-STICKY
policy-map type loadbalance http first-match SSLREDIRECT
  class class-default
    serverfarm SSLREDIRECT
policy-map multi-match CAS-Outlook-POLICY-MAP
  class CAS-Outlook-VIP
    loadbalance vip inservice
    loadbalance policy CAS-Outlook-policy
    loadbalance vip icmp-reply
    connection advanced-options TCP_IDLE_30min
policy-map multi-match CAS-http-POLICY-MAP
  class CAS-http-VIP
    loadbalance policy CAS-http-policy
policy-map multi-match CAS-https-POLICY-MAP
  class CAS-https-VIP
    loadbalance policy CAS-https-policy
policy-map multi-match CAS-imap-POLICY-MAP
  class CAS-imap-VIP
    loadbalance policy CAS-imap-policy
policy-map multi-match CAS-imaps-POLICY-MAP
  class CAS-imaps-VIP
    loadbalance policy CAS-imaps-policy
policy-map multi-match CAS-ipsec-POLICY-MAP
  class CAS-ipsec-VIP
    loadbalance policy CAS-ipsec-policy
policy-map multi-match CAS-pop3-POLICY-MAP
  class CAS-pop3-VIP
    loadbalance policy CAS-pop3-policy
policy-map multi-match CAS-pop3s-POLICY-MAP
  class CAS-pop3s-VIP
    loadbalance policy CAS-pop3s-policy
policy-map multi-match CAS-smtp-POLICY-MAP
  class CAS-smtp-VIP
    loadbalance policy CAS-smtp-policy
policy-map multi-match EXCH-POLICY
  class CAS-imap-VIP
  class CAS-imaps-VIP
  class CAS-pop3-VIP
  class CAS-pop3s-VIP
  class CAS-smtp-VIP
  class CAS-http-VIP
  class CAS-https-VIP
  class CAS-OUTL-MAPI-VIP
policy-map multi-match HUB-POLICY-MAP
  class HUB-VIP
    loadbalance policy HUB-policy
interface vlan 52
  description #### vlan client side EXCHANGE ####
  bridge-group 1
  access-group input BPDU-Allow
  access-group input EXCH-LB
  service-policy input REMOTE-MGT
  service-policy input HUB-POLICY-MAP
  service-policy input EXCH-POLICY
  no shutdown
interface vlan 54
  description #### vlan client side ACE_EXCHANGE ####
  bridge-group 1
  no shutdown
interface bvi 1
  ip address 172.22.101.123 255.255.255.192
  peer ip address 172.22.101.122 255.255.255.192
  description EXCHANGE-Bridged-vlans
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.22.101.126
Best Regards
5 Replies 5
b.youssef
Hi All,
Any help about the configuration provided !!
The problem that Outlook especially desn't work because of stikiness .
has anyone tested this solution "ACE Module for Loadbalancing Microsoft 2010 and LYNC or OCS" !!!
Best Regards
Have you checked in the sticky database if the dead server still appears ? If yes check the status of the probe, if everything is normal I would open a case.
Hi Surya,
When we shutdown a service on one node, the probe comes down (working fine) but in the sticky database it's still there !!!!
that's why Clients have problems (especially Outlook  which has three services) !!!
A case is openend with the TAC .
As Chris wrote in an answer (different thread) several minutes ago, you can configure a failaction on your serverfarm.
Thank you for your email. I am out of the office until March 25th, I will have limited access to my e-mail during this period.
In my absence, please feel free to contact Mr Akram Allani : aallani@3s.com.tn
Thank you for your understanding.
Best regards,
Youssef Boukari
