ACE30 and SHA-2
lfrc8554
Hi, does anyone know if ACE30 supports SHA-2 signed certficates?
2 Accepted Solutions
InayathUlla Sharieff
ACE30/ACE4710 support SHA-2 certificate on A4(1.0 or later version.
Inayath
Thanks for the update. Is there anything else I can help you further on this query? If No then May I request you to mark the thread as answered rather than leaving it to be open query, as that would  help others having the similar query.
regards
Inayath
Inayath
Thanks, I see indeed that the SHA256 is supported in version 5.3.1b which is the one I am working with:
RSA_WITH_AES_128_CBC_SHA256 Accept RSA_WITH_AES_128_CBC_SHA256 cipher
Luis
regards
Inayath
