ACE30: Rserver is Not Loadbalancing
Irvan Tambunan
Hi All,
I have ACE30 with multiple context. On some context, load-balacing is not working. Rserver connection is not equal. Client is accessing from VIP. Below is the log:
ACE/ccq# show serverfarm crm_fase1
   Codes: L - local,   R - remote
 serverfarm     : crm_fase1, type: HOST
 total rservers : 2
 state          : ACTIVE
 DWS state      : DISABLED
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: crm1
       10.6.82.156:5555      8   OPERATIONAL     122        75685756   35392
   rserver: crm2
       10.6.82.157:5555      8   OPERATIONAL     473        85749330   17836
ACE/ccq#              show service-policy crm_fase1_policy detail
Status     : ACTIVE
Description: -----------------------------------------
Interface: vlan 658
  service-policy: crm_fase1_policy
    class: l4_crm_fase1
     VIP Address:    Protocol:  Port:
     10.6.82.119     tcp        eq    5555
      loadbalance:
        L7 loadbalance policy: crm_fase1_loadpolicy
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        VIP DWS state: DWS_DISABLED
        Persistence Rebalance: DISABLED
        curr conns       : 584       , hit count        : 199508586
        dropped conns    : 45516
        conns per second    : 0
        client pkt count : 1263810860, client byte count: 2244901805384
        server pkt count : 1778561657, server byte count: 5666664200031
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : crm_fase1_loadpolicy
          class/match : class-default
            LB action: :
               sticky group: sticky_crm_fase1
                  primary serverfarm: crm_fase1
                    state:UP
                  backup serverfarm : -
            hit count        : 199463204
            dropped conns    : 6465866
            compression      : off
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
The problem is when rserver crm2 is down, some user seem to cannot login to system. Could you explain this behaviour.
I also attach my configuration and output from "show conn"
Thanks.
Irvan.
11 Replies 11
Kanwaljeet Singh
Hi Irvan,
You have failaction purge so i am not sure why some users will fail to connect once the real server fails. If the user tries to connect again, it should be loadbalanced to other real server in the serverfarm. What do you see in "show conn address <client ip>" during the problem?
Also, by default loadbalancing happens via round robin which is not a very good way to loadbalance. You can use least connections predictor and see if the unequal loadbalance situation improves.
You have sticky based on source and destination. This can be a problem when lot of users are coming from the same IP i.e behind the proxy or a NAT device. You can try changing "sticky method" as well.
Kanwal
Note: Please mark answers if they are helpful.
Hi Kanwal,
When rserver crm2 down, some users cannot login, but others is normal. This situation was weird. It has to be handled by rserver crm1.
Could give me script for least connections predictor?
Since, accessing the server via VIP only internally, then users are coming from their IP (not via proxy or NAT).
Thanks.
Irvan.
Hi Irvan,
For troubleshooting the issue when one rserver goes down, i would need more outputs during the problem itself.
For configuration of predictor least connections, you just need to do it under the serverfarm:
serverfarm host crm_fase1
  failaction purge
 predictor leastconns---------------------->Here is what you need to configure.
rserver crm1 5555
    probe crm_fase1_port
    inservice
  rserver crm2 5555
    inservice
Kanwal
Note: Please mark the answers if they are helpful.
Hi Kanwal,
In attachment, you can see output from "show conn".
For sticky configuration, i am using /24 subnet mask. Is it good for production environtment? Or i have to use only /32? What do you think?
As before, you said to change "sticky method". Could you elaborate this statement?
Thanks.
Irvan.
Hi All,
This case solved by changing subnet mask from /24 to /32 on stickiness configuration.
Thanks.
hey Kanwal,
hope you are doing great, i need some advise which is regarding VIP what if i do not state VIP INSERVICE Command and only VIP ICMP-REPLY
Hi Usman,
Interesting but i never did that myself.  Loadbalance vip icmp-reply will mean that even if serverfarm has failed the VIP will reply. "Loadbalance vip icmp-reply active" will mean that only if serverfarm is operational you will have the reply from VIP. But in both the cases loadbalance vip inservice should be there. This command makes the VIP active. If it is not there, i doubt that loadbalance vip icmp-reply will work.
Kanwal
yes Kanwal you are absolutely right i checked it with and without and saw that VIP ICMP-REPLY was good.
but even with vip inservice i see that i can work with http but cant terminate SSL on load balancer but its giving me a error like
Unable to make a secure connection to the server. This may be a problem with the server, or it may be requiring a client authentication certificate that you don't have.
Error code: ERR_SSL_PROTOCOL_ERROR..
can you help please
Hi Usman,
Share the configuration you have in place for SSL termination. What do you get on the client side packet captures while attempting to connect?
Kanwal
hey Kanwal the issue is resolved i think it was my bad somehow the other one of my class map was associated with wrong policy map which was creating an error space but i really appriciat your help by which i am keep improving myself.
thanks and best regards
Hi Usman,
Happy to be of help! Thank you for nice words.
Kanwal
