ACE4710 info about dropped connections
candrade
When I run the show service-policy I can find info about dropped connectios, but What is the cause of a "dropped connection" ?
Server? LAN? LoadBalancer?
What is understood for a "dropped connection"?
Dropped connection is not the same tha a timeout seesion. Isn´t it?
Status     : ACTIVE
Interface: vlan 1 16 21
  service-policy: int16-n2-1
    class: Virtual_WEB02-app_http
      loadbalance:
        L7 loadbalance policy: Virtual_WEB02-app_http-l7slb
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        VIP DWS state: DWS_DISABLED
        Persistence Rebalance: DISABLED
        curr conns       : 1361      , hit count        : 265760
        dropped conns    : 9582
        conns per second    : 0
        client pkt count : 1576014   , client byte count: 195873255
        server pkt count : 1472400   , server byte count: 630313128
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
I found useful info about it in
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_Troubleshooting_Layer_4_Load_Balancing
The dropped conns counter under a VIP in the output of the show service policy detail command is incremented whenever the ACE discards a connection request destined to that VIP. There are several reasons why the ACE discards such connection requests. For example:
  • If all the real servers in the server farm associated with the VIP go down, then the VIP will go down. So, all the incoming connections to that VIP are discarded.
  • If the URL in a connection request to the VIP is unknown, then the connection request is discarded.
  • If the server to which the ACE load balances the connection does not respond to the request, then, after the maximum number of retries, the ACE discards the connection.
About the second point (URL unknown). Is this a 404 error?
The reason for the drop is usually the server did not respond or server  responded with a RST or no server were active.
It might not be detectable, because a browser will usually retry immediately  if it does not get a response.
gaursin2
HI
Secind point of unknown URL could be a condition of L7 poilcy map where our L4 VIP class has hit and connection is accepeted, 3 way TCP handshake completeted by ACE with client but then client send L7 payload which doesn't match to any L7 class map and thats why ACE drop the connection.
Hope this help.
But is URL unknown a 404 error?
No, the situatuion which i have explained, ACE will send a RST to close the connection. Also i guess 404 is legitmate reply from server and should not be considered as a drop, unless server is sending a RST to close the same.
