ACNS nsc link issue
adrian_NA
Community Member
My windows player is returned with a link something like this http://server_ip/stream.nsc?item=12345&enviro=67890&type=.wmv
However when I try http://server_ip/stream.nsc it works fine.
My question is, why does the ACNS system fail when the link has parameters?
Thanks in advance.
chrhiggi
Level 8
Level 8
Adrian-
  I assume you are talking about a live channel setp on a CE by a CDM?  Exactly who is adding the parameters to the url?
  Normally, when you setup a channel, each CE that will be sending out a stream by itself. The reference NSC file to access the multicast parameters would be an http link with an FQDN of the CE itself, and a nsc file with the name of the video/channel. There would not generally be parameters passed into it.
Chris
