adding print drivers to a remote CM
axfalk
Level 7
Level 7
We have had a large deployment of WAE 512's and need to configure them as print servers as well. Some of the printers we need to incorporate are "non standard" , such as Zerox, Lexmark, etc. However, we have the print drivers for those printers. The CM server is located in a remote site. Does anybody know if we could add the printer drivers to the CM's repository remotely?
thanks..
Zach Seils
Level 11
Level 11
Hi Greg,
Yes, you can add print drivers to the CM Print Repository remotely. It may take a bit longer since you are remote, but it still works the same.
Zach
