Advanced-balance ssl problem
admin_2
Level 7
Level 7
Hi all,
We have a problem dealing using advanced-balance ssl with a CSS11501 and 2 apache servers.
When we use the "balance srcip" or "balance aca" alone, it works fine. But we would like to use "advanced-balanced ssl" method, as we have to deal with HTTPS flow...
Here is part of my running config :
circuit VLAN202
ip address XX.2.2.4 255.255.255.0
no redirects
circuit VLAN301
ip address XX.3.1.2 255.255.255.0
no redirects
service ssl_service1
port 443
protocol tcp
keepalive type ssl
ip address XX.2.2.11
service ssl_service2
port 443
protocol tcp
keepalive type ssl
ip address XX.2.2.13
content SSL_load_balancing
protocol tcp
port 443
application ssl
balance aca
add service ssl_service1
add service ssl_service2
vip address XX.3.1.50
active
I've a doubt about the SSL handshake because i can see from our FW that a the Web Server tries to answer directly to the client, while it gateway is the CSS....
Any help or idea about my config will be appreciated...and plz excuse my bad english..
andrew.thomson
Level 2
Level 2
We have Advanced-Balance SSL but have included a line:
url "/*"
in the content rule. I think this forces the protocol up to layer 5 where the SSL ID can be found.
Good luck
Andrew
Gilles Dufour
could you please provide some information about the problem itself.
Is it every connections or just a few of them ?
If you see the server bypassing the CSS, that would be a concern.
Can you sniff the server side and see the mac address of the SYN/ACK.
Also check where it breaks exactly in the TCP connection.
The url command is not required.
The command application ssl will make the CSS look for the session id.
Gilles.
Thanks for your help...
Let me explain my case better.
All connections are "refused" when i use advanced-balance ssl. But if i put it away (i.e. using only balance srcip or else), it works fine (hopefully!)
From my FW monitor, i can see the syn/ack flow :
SYN / From:myPC / Destination : XX.3.1.50 / Service :https/443
ACK / From:XX.2.2.13 / Destination : myPC / Service:4435 / Reason : no connection found for TCP packet
Perhaps that is the problem : it should be the CSS that sends the ACK to the client ...?
Anther point : from llama, i can see an increasing number of WCC_REJECTED from the Apache_side_vlan...
I will try to see where the TCP connection stops but i'm not used to working with sniffer...
Hope these informations can help ! Any idea ?
