Analyze ACE capture buffer
resbanknet
Frequent Visitor
Frequent Visitor
Good morning.
I am able to take an ACE capture buffer and get it into a file on a PC. However, this format isn't very readable. Can someone please point me to a tool which can convert the file into something legible, or else explain to me how I can convert it manually?
TIA
- Godfrey
Gilles Dufour
With the latest software version, when you do 'copy capture disk0:' the capture is converted into a pcap file readable with any sniffer tool like wireshark.
Just rename the file into something.cap and if you have wireshark, it should be able to decode it.
Gilles.
Thanks, I never realised that there was a difference between this method and the
sh capture BUFFER detail > tftp: way.
