ANM-2.1 - Monitoring ACE realserver connections
javiercastro
I have just installed ANM-2.1 in order to manage two ACE modules working in redundancy. I have found that it is possible to see the number of current connections to each server of any serverfarm. It is also very important to see the client IP address of each connection, not only the number of connections.
Does anybody know if is possible using ANM?
tstanik
Level 5
Level 5
ANM currently does not display details of concurrent connections. On ANM you should be able to see the total of number of Concurrent connections. But you cannot see the associate source and destination IP addresses and port numbers.
