ā03-22-2011 10:30 PM
The documentation for configuring Tacacs authentication at this link (http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/application_networking_manager/4.2/user/guide/UG_admin.html#wp1267519) states the following:
Note For the ACE to properly perform user authentication using a TACACS+ server, the username and password must be identical on both ANM and the TACACS+ server.
If the user id and password have to be the same, what is the point of using Tacacs for authentication? Someone tell me that I can use a TACACS+ server without being forced to keep the user id and password synched between ANM and Tacacs.
ā04-08-2011 12:19 AM
You are right, this is incorrect. I opened defect CSCto56003 to get this addressed. Using tacacs there is no requirement to set user password on the anm side. The doc will be corrected. Thanks for pointing this out.
Matthew
ā04-14-2011 12:35 AM
