Arrowpoint CS-800 Flows
jivarva
Community Member
How is the maximun flows that support CS-800..??
I have a problem when flows go up to 7000.
Maybe, the "flow timeout" is the solution..??
This is the "flow stat"
Flow Manager Statistics - SFM Slot 9, Subslot 1:
Cur High Avg
UDP Flows per second 0 258 0
TCP Flows per second 47 1289 49
Total Flows per second 47 1291 49
Hits per second 167 543 179
Port Active Total TCP UDP
#11/1 310 56143045 310 0
#11/2 173 63890499 173 0
#11/3 352 63065305 352 0
#11/4 415 90889158 415 0
#11/5 223 60797707 223 0
#11/6 184 64834916 184 0
#11/7 0 7320611 0 0
#11/8 0 0 0 0
#12/1 338 106518647 338 0
#12/2 387 89681467 387 0
#12/3 265 43534400 265 0
#12/4 149 50599867 149 0
#12/5 0 0 0 0
#12/6 179 62061854 179 0
#12/7 0 0 0 0
#12/8 0 0 0 0
Flow Manager Statistics - SFM Slot 9, Subslot 2:
Cur High Avg
UDP Flows per second 0 245 0
TCP Flows per second 65 1274 51
Total Flows per second 65 1275 51
Hits per second 166 497 169
#13/1 0 0 0 0
#13/2 377 41276241 377 0
#13/3 261 100451137 261 0
#13/4 154 52512707 154 0
#13/5 545 120438970 545 0
#13/6 0 0 0 0
#13/7 0 0 0 0
#14/1 0 0 0 0
#14/2 1 5360071 1 0
#14/6 4553 1223090599 4552 1
active-800#
Gilles Dufour
what version do you have ?
In which mode did you capture the flow stat ?
[did you capture it from debug/llama mode ?]
What kind of problem do you have ?
The CSS800 should be able to handle much more flow than 7000.
Gilles.
Hi Gilles,
Version is 5.00 Build 69
Mode enable, I just make a command "flow stat"
The problem is that when flow arrive to 7200, it reboot.
Note that the CSS800 is redundant on itself.
Thanks for your help
Javier
