ASA not authenticating waas 512
Srin_G
Level 3
Level 3
Hi Guys,
Got a issue here with trying to authenticate a cisco waas with ASA.
Below is the debug message in the asa:
WCCP-EVNT:D61: Here_I_Am packet from 10.97.40.25: authentication failure
WCCP-EVNT:D62: Here_I_Am packet from 10.97.40.25: authentication failure
Global WCCP information:
    Router information:
        Router Identifier:                   -not yet determined-
        Protocol Version:                    2.0
    Service Identifier: 61
        Number of Cache Engines:             0
        Number of routers:                   0
        Total Packets Redirected:            0
        Redirect access-list:                wccp_list
        Total Connections Denied Redirect:   0
        Total Packets Unassigned:            0
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       10370
        Total Bypassed Packets Received:     0
I have attached the network layout!
I use wccp-gre and wccp negotion in the waas connected to nexus!
The WCCP-L2 has no issues at the edge site.
Any inputs on this issue is appreciated
regards
8 Replies 8
Felix Arrieta
Not 100% sure but I think you are hitting the following bug  CSCts15920
please check the workaround and current ASA version:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCts15920
Felix
Thanks mate.
We run v 8.6.1 in the Asa and 4.4.5c in the wae apparently Cisco doco says that bug has been fixed in 8.6.1!
Well, if the password is the same on both units and still not authenticating sounds like a bug to me, I suggest to follow the workaround  by now and open a TAC case to check on ASA and WAAS statements, replicate the problem and see how it goes.. chances are either a wrong configuration or guideline not being follow or a new bug.
Felix
Cisco doc say ASA version 9 doesn't support waas devices?!
really! I wonder why... can you share that doc please.
Felix
yeah i cant believe it either! http://www.cisco.com/en/US/docs/security/asa/asa90/configuration/guide/access_wccp.html#wp1105267
The following WCCPv2 features are not supported for the ASA:
Multiple routers in a service group.
Multicast WCCP.
The Layer 2 redirect method.
WCCP source address spoofing.
WAAS devices.
I will try to set up a lab  and let you know if there'sa nythnig helpful.... I have move to another technology  and I really have no time right now..=(..
good luck!
Felix,
no worries mate. We are thinking of using 2911 with security license and working on it in the lab.
cheers
