Auto failover if SSL module breaks?
gvpelt
Community Member
Got 2 CSS in VIP redundancy and a critical-server script that’s pinging up and downstream routers off active CSS.
If the SSL module fails, will the backup CSS takes over?
Configuration of our CSS is very basic
service ssl_module1
type ssl-accel
keepalive type none
slot 5
add ssl-proxy-list test
active
Kind Regards,
Gerrit Frans
Gilles Dufour
if the CSS module fails, the CSS will force a reboot of the entire box, therefore forcing failover to the standby.
Gilles.
We using ip virtual-router 1 priority 110 preempt on the primairy box.
Looks like we can beter remove the preempt command?
Gerrit Frans
