Backend SSL and http keepalives
dennis-hess
I know it's not possible to do ssl keepalives but I have the need to do more than port keepalives on a ssl web site due to the page failing at times. I'm about to implement back-end ssl with an ssl module and I'd like to make a keepalive to a html page. Can I just put a http keepalive on the backend service? I checked the config guides and CCO and I couldn't find guidance as to whether this would work. Thanks DH
7 Replies 7
casablancag
from my point of view, it is possible to do an ssl keepalive with version 7.5. I've tested it and it works fine.
We're still running 7.3. I'll look at 7.5 and consider upgrading but I'm still curious about the original question. Also, I shouldn't have said ssl keepalives but rather https page keepalives. I need to check more than the port to ensure functionality. Thanks
Yes i made an encripted http get. It works fine
Ah ok... thanks casablanca, I was wondering about that. Normally I'd just try it and find out but I don't have a test box and I need an answer for the app folks. So did you just put the http keepalive on the backend service, like so? If not, would you be so kind as to post a config example? Thanks!
service backend2
ip address 10.1.1.21
type ssl-accel-backend
port 81
keepalive port 8003
add ssl-proxy-list my_secure_site
keepalive type http
keepalive method get
keepalive uri "/index.html"
protocol tcp
active
You can't do HTTPS keepalive unless you have 7.50.
If you don't have 7.50, all you can is check the first step of the SSL negotiation.
Gilles.
Thanks Gilles,
I'll investigate upgrading to 7.50. How about the original question? I guess you're saying that is it not possible with pre 7.50 code to configure http keepalives on the backend service. In other words, the CSS will do a http keepalive which the ssl module then encrypts with ssl and sends to the back end server?
you can do http keepalive with any version on a backend service.
All you need is this :
keepalive type http
keepalive port 80
keepalive uri "..."
The CSS does not require the service type to match the keepalive type.
Gilles
