Bad performance on routing between two vlan on ACE 4710 routing
lucas restrepo
HI,
The topology I am working on is the connection of a web server running PHP to the internet using a load balancer between the internet and the server farm.
The server farm is connected to vlan 50 and the database servers are connected to vlan 60. Both vlans are connected to the load balancer ACE 4710.
What I can see is that the traffic between the two vlans is very slow. Some times the application can not even connect to the database and if I start a ssh to one of those servers the connection is very slow and it takes almost two minutes for the system to prompt me for the password.
I don’t know why this system is performing this way since I have all the configuration wright and I have a permit all ACL on both interfaces.
The other thing that a can see is that the ACE is holding back connections from the Internet to the server farm and that makes that connection slow too.
What can I do and how can i approach this issue.
Best regards.
Lucas.
Hi Lucas,
As you may already know using the ACE to route the traffic between VLANs is not a good idea considering the fact that the ACE is meant to load balancing the traffic.
The ACE has muliple performance limitation; bandwidth, concurrent connection, sticky .. etc.
I would advice you to start with defining the issue more:
- How often are you facing this performance issue? Are you facing this issue under any specific condition?
- Have you noticed this issue newly or it has been effecting the setup since day one? If No, what have been changed recently which triggered the issue?
- Are you facing this performance issue for all kind of traffics going through the ACE or only between these two VLANs?
Second, monitoring the ACE resource usage while facing the issue:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_Troubleshooting_Performance_Issues
Then, try to to capture the traffic on the source PC, destination PC and ACE simultaneously, then start comparing the time-stamp on wireshark to understand the source of the delay.
Best regards,
Ahmad
lucas restrepo
here is the configuration i have layed out for this load balancer.
i have motied some configuration like an access list for the vip and the external ip but all the interesting traffic is permited.
access-list ALL line 8 extended permit ip any any
access-list captura line 2 extended permit ip host 10.10.10.7 any
access-list captura line 3 extended permit ip any host 10.10.10.7
probe icmp pingeuropa
  interval 10
  faildetect 5
  passdetect interval 60
probe http web-server
  interval 5
  passdetect interval 5
  expect status 200 399
  open 1
probe https web-server-europa
  interval 5
  ssl version all
  open 1
probe http web-server-portal
  interval 5
  open 1
parameter-map type connection test
rserver host web-app
  ip address 10.10.10.5
  inservice
rserver host web-app-portal
  ip address 10.10.10.6
  inservice
serverfarm host Balanceo_WEB_APP
  predictor leastconns
  probe pingeuropa
  rserver web-app
    inservice
serverfarm host Balanceo_WEB_APP_https
  probe pingeuropa
  rserver web-app
    inservice
serverfarm host Balanceo_WEB_APP_portal
  probe pingeuropa
  rserver web-app-portal
    inservice
sticky ip-netmask 255.255.255.255 address source Balanceo-web-server-STICKY
  timeout 14400
  replicate sticky
  serverfarm Balanceo_WEB_APP
sticky ip-netmask 255.255.255.255 address source Balanceo-web-server-portal-STICKY
  timeout 14400
  replicate sticky
  serverfarm Balanceo_WEB_APP_portal
sticky ip-netmask 255.255.255.255 address source Balanceo-web-server-europa-STICKY
  timeout 14400
  replicate sticky
  serverfarm Balanceo_WEB_APP_https
class-map match-any Balanceo-WEB-europa
  2 match virtual-address 200.x.x.x tcp eq www
  4 match virtual-address 190.x.x.x tcp eq www
class-map match-any Balanceo-WEB-europa-https
  2 match virtual-address 200.x.x.x tcp eq https
  4 match virtual-address 190.x.x.x tcp eq https
class-map match-any Balanceo-WEB-portales
  2 match virtual-address 190.x.x.x tcp eq www
  4 match virtual-address 200.x.x.x tcp eq www
class-map match-any TCP_CLASS
  2 match any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match L7_VIP_LB_WEB
  class class-default
    sticky-serverfarm Balanceo-web-server-STICKY
policy-map type loadbalance first-match L7_VIP_LB_WEB_europahttps
  class class-default
    sticky-serverfarm Balanceo-web-server-europa-STICKY
policy-map type loadbalance first-match L7_VIP_LB_WEB_portal
  class class-default
    sticky-serverfarm Balanceo-web-server-portal-STICKY
policy-map multi-match L4WEB
  class Balanceo-WEB-europa
    loadbalance vip inservice
    loadbalance policy L7_VIP_LB_WEB
    loadbalance vip icmp-reply active
  class Balanceo-WEB-portales
    loadbalance policy L7_VIP_LB_WEB_portal
  class Balanceo-WEB-europa-https
    loadbalance policy L7_VIP_LB_WEB_europahttps
policy-map multi-match TCP_POLICY
  class TCP_CLASS
    connection advanced-options test
interface vlan 10
  ip address 200.x.x.x 255.255.255.248
  peer ip address 200.x.x.x 255.255.255.248
  access-group input web
  access-group output web
  service-policy input L4WEB
  no shutdown
interface vlan 20
  ip address 190.y.y.x 255.255.255.248
  peer ip address 190.w.y.x 255.255.255.248
  no shutdown
interface vlan 50
  ip address 10.10.10.2 255.255.255.0
  peer ip address 10.10.10.3 255.255.255.0
  access-group input ALL
  access-group output ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 60
  ip address 10.10.20.1 255.255.255.0
  peer ip address 10.10.20.2 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 200.13.228.137
ip route 192.168.0.0 255.255.0.0 10.10.10.1
this is the output of the resource.
                                                     Allocation
        Resource         Current       Peak        Min        Max       Denied
Context: Aplication
  conc-connections             24       2002     800000    1200000          0
  mgmt-connections              4         44      40000      60000          0
  proxy-connections             0         23     104857     157286          0
  xlates                        0          0      26214      39321          0
  acc-connections               0          0         20         30          0
  bandwidth                131252    9356738   53687091  205530637          0
    throughput                180    4965826   53687091   80530637          0
    mgmt-traffic rate      131072    4390912          0  125000000          0
  connection rate               0        257     400000     600000          0
  ssl-connections rate          0          1        400        600          0
  mac-miss rate                 0         88        800       1200          0
  inspect-conn rate             0          0      16000      24000          0
  http-comp rate                0          0    5242880    7864320          0
  acl-memory                49328      76720   15018736   22531277          0
  sticky                        0       1880     327680          0          0
  regexp                      914        914     419430     629146          0
  syslog buffer                 0          0     418816     629760          0
  syslog rate                   0          0      40000      60000          0
as i have said the connection between the network 10.10.10.0 and the 10.10.20.0 are very slow and the conections fron the internet the load balancer cut allot of connections of the web aplication.
best regards.
