basic and advanced src-ip balancing
skumar1969
Level 4
Level 4
What is the 'key' difference between the basic src-ip method and the advanced sticky src-ip methods?
I can understand in the advanced one, CSS actually "sticks" a client to a server based on the client's source IP address.
I can understand the basic one as well, CSS directs all client requests coming from the same source IP address to the same service. So, this method too provides a bit of stickness.
The question is how does they differ from each other, in what detail.
Got any clue.
thanks
Gilles Dufour
the sticky method (advanced) creates a sticky table, each entry containing client-ip/server-ip. When a server goes down, the entry is removed and a new one created.
The standard method does not use a sticky table but a hash algorithm. The algorithm takes the client ip and returns the index of a server.
The same client ip returns always the same index.
If a server goes down, the algorithm select the next available index.
This is where is the difference.
Assume the hash algorithm returns index of server-A. While A is alive, everything is fine. When A goes down, traffic will be sent to the next index, let's say B.
When A comes back alive, traffic is again sent to A.
With the advanced method, since a new entry pointing to B is created when A is down, when A comes back up, traffic is still sent to B.
Another difference is if you add or remove servers from the list. The hash algorithm may return different index.
Gilles.
Gilles Dufour
Gilles.
