Box to box redundancy
rmendes
Is it possible to configure more then one redundancy link in a box to box redundancy ?
pknoops
Level 3
Level 3
Using more then one link for your heartbeat or redundancy-protocol link is not supported and quite honestly will not work properly anyway simply due to some bridging holes that needed to be put into the code to avoid dropping VRRP frames with a CSS 11000 MAC address.
Pete Knoops
Cisco Systems
Thanks Pete
