c6513 Ace Module Pair not syncing
Adrian Jones
I have a failover pair of Ace Modules that have stopped syncing - Active not syncing with Standby. I have checked the config and it seems that recent additions of contexts in the Admin Context to resource groups and fault tolerant additions of ft groups have not synced across to the standby unit. All other config checks out as okay.
Can anyone point me in a good direction to restart the sync?
Adrian
chrhiggi
Level 8
Level 8
Adrian-
  To see the error - login to the context that isn't syncing and issue "show ft config-error"
  Scripts and SSL keys/certs are not synced over, they will cause an FT sync error.  If that was what happened, then upload the files to the context, then toggle "ft auto-sync running-config" on the active context and it will re-try the sync.
  If the issue was not key/cert or script related, get a TAC case open, it is extremely likely there is a bug involved.
Chris
