Cach Engine Boot Failure
davidcruise
Level 2
Level 2
I have WAE 500 , installed ACNS 5.3.3.8 on it , transferred it to a new location in the datacenter , then at power on i found the following output:
IBM BIOS (C) Copyright IBM Corporation 2004
Intel(R) Pentium(R) 4 CPU 1.86GHz
512M System Memory Installed
293M System RAM Passed
Event Log messages, enter Setup to view
8603 Pointing Device Error
1780 Hard Drive error - IDE only
162 Device configuration error
Press <ENTER> to resume, <F1> to Setup
| Processor : Pentium 4 System ROM : E0EF - FFFF |
| Processor Speed : 1.86 GHz BIOS Date : 10/11/05 |
| Physical CPUs : 1 |
| COM Ports : 03F8 |
| System Memory : 624 KB LPT Ports : None |
| Extended Memory : 512 MB PS/2 Mouse : Not Installed |
| Shadow Ram : 384 KB |
| Cache Ram : 1024 KB |
| Diskette Drive A: : 1.44 Mb 3.5" |
| Primary Master : None |
| Primary Slave : HL-DT-ST GCR-8240N-(PS) |
| SATA Port 0 : HDS728080PLA380-(S1) |
| SATA Port 1 : HDS728080PLA380-(S2) |
Press Any Key to Continue
ntel(R) Boot Agent GE v1.2.17
Copyright (C) 1997-2003, Intel Corporation
Intel(R) Boot Agent PXE Base Code (BA1217BC)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel Boot Agent.
1962 Drive does not contain a valid boot sector
Operating System not found
So is this considered hardware failure ?
dstolt
Is it a WAE-511 or 512? Since you just moved it, I would open it up and see if the flash or if the drive connections are loose. Definitely start with the flash drive (inside above where the floppy would be).
Dan
dstolt
Dan
It is 512 , but i have a question :Is the Boot sector is on the flash or the Hard disks ?
Sorry it is 511, i changed the compact flash (it was faulty) , then reimaged the appliance , and now it is working normally.
now the question is there is led beside the compact falsh that is red ,& after i changed the flash it still red although the box now is operating normally?
