cache engine IP spoofing with CSS ?
alpritchard
Community Member
i would like to use css and cache engine in a spoofed ip source design to preserve identity of requestor.
WCCP appears to be able to do this but not L4+ switching with CSS.
Does anyone know of a way of doing this either as a transparent cache or proxy cache ?
thanks in advance
Gilles Dufour
Alan, we discussed this by email in the case you opened.
The command 'wccp spoof-client-ip enable' does work on the CE even
if you are not using WCCP.
On the CSS, just make a config similar to the one for one-armed transparent SCA config.
Tested in the lab and it works.
Gilles.
