Cache Engine problem with real time data on Port 80
jjpeyrache
hi
customer claims real time data HTTP doesnt work on cache engine V2.31
is it normal , do we need to upgrade to V3.11 in order to support streaming ?
thanks for any advice
JYP
mchin345
Level 6
Level 6
I am not sure why it is not working. Upgrading is a good idea, but I guess you would need to also find out why it is not working. the following doc has a configuration example. Hope it helps.
http://www.cisco.com/en/US/products/hw/contnetw/ps546/products_configuration_example09186a008009460a.shtml
thanks i'll check do
