can CSS11501 without ssl module load balancing https
lanningye
Community Member
Anyone could help me?
We have a CSS11501 NAME: "chassis   ",  DESCR: "Cisco 11501 Content Services Switch with Hard and AC Disk"
PID: CSS11501
I just found out that this hardware doesn't have SSL module built in.
We have two Web Server running IIS. we are going to apply SSL wildcard certification to the server for multi-domain access. I wonder if it possible to use this CSS to provide load balance to access these two server with https request? Even just access one server without load balancing? My configuration is as below:
configure
!*************************** GLOBAL ***************************
  ip route 0.0.0.0 0.0.0.0 193.39.xx.xx 1
!************************* INTERFACE *************************
interface e1
  bridge vlan 2
interface e5
  bridge vlan 3
interface e6
  bridge vlan 3
interface e7
  bridge vlan 3
interface e8
  bridge vlan 3
!************************** CIRCUIT **************************
circuit VLAN2
  ip address 193.39.xx.xx 255.255.255.192
circuit VLAN3
  ip address 192.168.10.1 255.255.255.0
!************************** SERVICE **************************
service Server1
  ip address 192.168.10.3
  keepalive type tcp
  keepalive port 80
  active
!*************************** OWNER ***************************
owner Test
  content Test
    vip address 193.39.xx.xx
    protocol tcp
    port 443
    add service Server1
    active
BETEGUCSS01#
Why I could access https://localhost on the webserver, but can't access VIP via the load balancer https://193.39.xx.xx ?
Any help would be very appreciated!
Hey Lanning,
Ok gotcha! In that case let's create a basic L4 load balancing for HTTP and HTTPS.  We need to split up the services and rules as follows:
service Server1-HTTP
  port 80
  keepalive type tcp
  keepalive port 80
  active
service Server1-HTTPS
  port 443
  keepalive type tcp
  keepalive port 443
  active
owner Test
  content Test-HTTP
    protocol tcp
    port 80
    add service Server1-HTTP
    active
owner Test-HTTPS
  content Test
    protocol tcp
    port 443
    add service Server1-HTTPS
    active
Check the service status and then send some request to the VIPs and gather the output of show summary to confirm the
request are hitting the CSS.
I have a little suspicion that you have an asymmetric routing issue going on... Is this server dual-homed?
Regards.
__ __
Pablo
6 Replies 6
sachinga.hcl
Level 10
Level 10
Kindly send the output of the following command:
#show chassis
Sachin Garg
Hi Sachin
Here is the output:
Configuration for CSS11501 P0:
Product Name:    CSS11501 P0        SW Version:        08.20.0.01
Serial Number:   JMX1411600A        Base Mac Address:  68-ef-bd-99-36-24
Module Number   Module Name         Status
      1         CSS501-SCM-INT      primary
Port Number     Port Name           Status
      1             e1              online
      2             e2              online
      3             e3              online
      4             e4              online
      5             e5              online
      6             e6              online
      7             e7              online
      8             e8              online
      9             e9              online
Thanks for your reply and help!
Lanning
Hi Pablo
The web server is in both http and https. I also would like to have be able to access both http and https to the server. Haven't figured out how yet. But firstly https doesn't work.
The Service is alive:
Service Name                     State     Conn  Weight  Avg   State
                                                         Load  Transitions
Server1                          Alive         6      1     2           42
Any chance to spot any other problem in my configuration?
Lanning
Hey Lanning,
  port 80
  keepalive type tcp
  keepalive port 80
  active
  port 443
  keepalive type tcp
  keepalive port 443
  active
owner Test
  content Test-HTTP
    protocol tcp
    port 80
    active
owner Test-HTTPS
  content Test
    protocol tcp
    port 443
    active
Regards.
__ __
Pablo
Thanks Genuis Pablo, working like charm..
pablo.nxh
Level 8
Level 8
Hi Lanning,
Perhaps when you switched to HTTPS in your backend server HTTP is not longer active that action could've brought down
the keepalive on the CSS so no LB can be performed as only one service is configured.
Please check with show service summary the state of the service, if down then remove the keepalive or change the port to be 443.
*HTTPS LB works on the CSS regardless of  not having an SSL-M, the module only takes care of SSL offloading.
__ __
Pablo
