CE-565 CPU load issue after upgrading to 5.0.5
Valther
After upgrading our CE-565 to 5.0.5, every 70 minutes we get a syslog message like this:
Aug 18 11:33:17 DC-R-CE1 overload: %CE-BYPS-5-130007: OVERLOAD: Preload did not receive overload message. Preload may not be
running
The CE is configured as a transparent web-cache only. It runs currently in a trial setup with minimal load. No preload is configured. However, looking at the GUI's "usage" graph it seems that the CPU load jumps up to 50% at the same time as the error message is generated.
Any idea why ?
Valther
owillins
Level 6
Level 6
I guess you are hitting bug CSCdz73145 . It means that the CE does not have preload configured. It usually occurs in 5.0. You may ignore it, it's a cosmetic issue and doesn't have any impact on the normal operation.
