CE-7305 and natting
cjuba
Does the CE require a static nat entry on the edge router in order to function properly?
mchin345
Level 6
Level 6
Yes, a Static NAT entry is needed for the CE to function. NAT uses timers on each translation entry to remove entries that are no
longer being used. The timer mechanism being used turns out to dramatically increase CPU utilization for large numbers of NAT translation entries.
