CE505 boot problem. Help needed, ASAP
vault_dweller
Visitor
One day old (still rocks! :)) working CE-505 stop booting with:
--- boot msg ---
Press any key to stop auto-boot...
auto-booting...
boot device (flash,net) [ net]:
file name [ ce505-cache-231.bin]:
cache IP address [ 192.168.0.99]:
IP network mask [ 255.255.255.0]:
server IP address [ 192.168.0.10]:
protocol (rcp,ftp,tftp) [ tftp]:
flags [ 0]:
Loading from the network
Attaching network interface fei0... done.
Attaching network interface lo0... done.
Loading... Starting at 0x108000...
#!ImageInfo
# | CISCO CE image |
SUPPORTED_PRODUCTS=CE505,CE550
UNCOMPRESSED_CKSUM=0xf17c87d3
UNCOMPRESSED_SIZE=0x3578b8
COMPRESSED_CKSUM=0xd6ab0b3
COMPRESSED_SIZE=0x167cdb
This image supports models CE505,CE550 and this appliance is a 00000.
--- boot msg ---
And start timer again 😞 I tryed booting from network because flash boot fails similar above. I see IOS booting message and then boot counter again 😞
Can any one help me with this issue?
P.S. Sorry for my english.
Zach Seils
Level 11
Level 11
Paul,
This indicates that the flash is corrupted. You will need to RMA/replace the device.
~Zach
7 Replies 7
Zach Seils
Level 11
Level 11
Paul,
~Zach
THANK YOU! but... how this can be? i opened this black box and this is PC! mabe if i clean BIOS by removing battery helps? i realy don't have any idea 😞
The flash contains specific information about the hardware that is used by our software to determine which versions are supported, what drivers to use, etc. In our newer hardware, we support re-writing the flash by booting from a special rescue CD. Since the CE505 does not have a CD-ROM drive, flash corruption is resolved by replacing the device.
~Zach
i have two working ce-505 and can i read his flash data and write it on corrupted flash? or can you recommend cisco's partner in rusia who can repair this device?
You would not be able to restore the flash from another working CE.
You can search for Cisco partners using the Partner Locator tool on CCO:
http://tools.cisco.com/WWChannels/LOCATR/jsp/partner_locator.jsp
regards,
Zach
THANK YOU! again
It's me again with another CE 505. I van't understand what happens, but one day flash boot fail and i try to boot from network:
auto-booting...
file name [ ce505-cache-251.bin]:
cache IP address [ 10.10.10.120]:
server IP address [ 10.10.10.10]:
flags [ 0]:
Loading... image read failed: Image is not for x86 CPU: errno=0x16
Error loading file: errno = 0x31.
Can't load boot file!!
Why CE can't boot? I downloaded image from anothe working CE
Thank you.
