CE550 and two backbone
mehrdad
Level 7
Level 7
we are using CE550 and 7200VXR , we have two range ip and two backbone
how can using these two backbone by one CE550 ?
it seems CE550 can have one ip address and using that .... i don't know how to setup it for two ip addresses (tcp outgoing) for using two backbone.
i would be appreciate if you advice me.
M.Arshad Rad
Gilles Dufour
if you have 1 router and 2 backbone, it means the router is attached to both.
Therefore, I would suggest to simply put the CE in one of the backbone and use wccp to transparently redirect traffic from both backbone to the CE.
For example, assume your 2 backbone are respectively on interface fast 0/0 and fast 0/1.
You will put the CE on interface fast 0/0.
On the router you will configure
ip wccp version 2
ip wccp webcache
interface fast 0/0
ip route-cache same-interface
! important because this is where the cache is located
ip wccp webcache redirect in
interface fast 0/1
On the cache, use just 1 interface with 1 ip address from the backbone 1 range. Then configure
wccp router-list 1
wccp version 2
wccp webcache router-list 1
Hope this help.
Gilles.
