sticky rules for 11501?
john-lucero
Can anyone direct me to any white papers discussing in depth setting up
I am new to this and need to establish load balancing between PeopleSoft portal servers. While I am getting the basics down, I need to get quickly educated on the process. The basic documentation seems to have left me a little confused. Probably due to my lack of understanding of Web based applications.
Your assistance is appreciated.
Gilles Dufour
I would suggest to start from here :
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guides_books_list.html
if you need clarification do need hesitate to send us your questions.
Gilles.
abenanti
I implemented the css on peoplesoft portal server. it works pretty fine. the only thing you should have en eye on is on the stickyness. we used "sticky source ip". we saw that if we used sticky by netmask for example class C network, it did not work well. and do not use ssl cookie session id stickyness. it can be thath the IE (microsoft) change the ssl session id for the same session several times.
andrea
