CE590 Websense integration issue.
allissrcco
Community Member
I have a CE590 which I am trying to set up as a transparent cache using a Websense server for URL filtering. Everything seems to work fine if I have Allowmode enabled but I get incomplete pages and the 'URL requested was filtered' page if I disable the Allowmode.
The Cisco instructions for setting this up are quite simple but I cannot work out what is causing this error.
Can anyone help me?
Richard.
owillins
Level 11
Level 11
Make sure you have selected the "Cisco cache engine" option when installing websense.
Try uninstalling and re-installing again. Get an eval key for the Content Engine Edition and check if it works.
