Problem with Web sites and web based application with CE 560
srosenthal
Level 4
Level 4
I installed at Content Engine 560 with a 3745 router running WCCPv2. The box seems to be working fine and is showing a savings.
The customer has informed me that an internal web site now asks the users to log in and before the install never did. Also, they said they are having some problems with internal web based applications.
Any advice as to what might be causing this?
Seth
owillins
Level 6
Level 6
In order to prevent some urls and internal websites from being cached use url bypassing. This way these urls will not be cached and the users can directly use them without being asked to log in.
To enable transparent error handling and dynamic authentication bypass, and to configure static bypass lists, use the bypass global configuration command. To disable the bypass feature, use the no form of the command.
hugues.lavoie
You also can use Access-list to select traffic to redirect to your CE. This unload your CE from any working with your Intranet data.
