Certificate per box or per vip?
kelvin-yeo
Hi pros,
Just a short one on certificate.
If my CSS(1 SSL module) is serving 3 different SSL VIPs, do i need to install 3 pairs of keys/cert, or only required 1 pair of key/cert per CSS?
eg,
content https1
vip address 192.168.99.90
application ssl
add service x
protocol tcp
port 443
active
content https2
vip address 192.168.99.91
application ssl
add service x
protocol tcp
port 443
active
content https3
vip address 192.168.99.92
application ssl
add service x
protocol tcp
port 443
active
So does the above all points to 1 same 'ssl_front' ?
service ssl_front
keepalive type none
slot 2
add ssl-proxy-list ssl-list1
type ssl-accel
active
Rdgs,
confused
browsers verify that the name of the server matches the name of the certificate.
So, you'll need 3 certificates or 1 wildcard certificate.
This is a certificate with a name like *.auto.com.my.
So, see what is cheaper for you.
Gilles.
kelvin-yeo
i did a research in this forum. understand that certificate relates to the domain.
if 3 above contents serve below urls respectively,
www.auto.com.my - 192.168.99.90
backoffice.auto.com.my - 192.168.99.91
tr.auto.com.my - 192.168.99.92
then i believe i need to only subscribe 1 verisign certificate using 'auto.com.my' and then point these services to same "ssl_front". please correct me if im wrong anywhere...
cheers
Gilles.
