Cisco 11503 & Ping issue for one Virtual host
sandeep.menon
  Dears
I have a single  cisco 11503 load balancer.
There is a single Banner student information system which is load balanced on it with Virtual ip 10.3.20.101 which is working fine without any issues .
I am now trying to add an Oracle ERP application with virtual IP 10.3.20.230 and physical ips 10.3.19.22 and 10.3.19.23 all on port 8003.
When I just make the group  ERP-Apps-Grp active , the vitual ip address 10.3.20.230 is pingable , but when I make the  the content Erp_IAT active  it stops pinging.
Appreciate if you give me any insight . I am not much well versed with load balancer, but I tried making the configuration seeing the working ip 10.3.20.101 Please find the problem configuration below highlighted in bold
  ip route 0.0.0.0 0.0.0.0 10.3.20.254 1
!************************* INTERFACE *************************
interface  1/2
  bridge vlan 10
!************************** CIRCUIT **************************
circuit VLAN1
  ip address 10.3.20.100 255.255.255.0
circuit VLAN10
  ip address 10.3.19.1 255.255.255.0
!************************** SERVICE **************************
service Banner-Apps-1a
  ip address 10.3.19.11
  keepalive type http
  port 7777
  active
service Banner-Apps-1b
  ip address 10.3.19.15
  keepalive type http
  port 7777
  active
service Banner-Apps-1c
  port 14021
  keepalive type tcp
  active
service Banner-Apps-1d
  protocol udp
  port 14021
  keepalive type http
  active
service Banner-Apps-1e
  keepalive type tcp
  port 14021
  active
service Banner-Apps-2b
  ip address 10.3.19.16
  keepalive type http
  port 7777
  active
service Banner-Apps-2c
  keepalive type http
  port 14021
  active
service Banner-Apps-2d
  protocol udp
  port 14021
  keepalive type http
  active
service Erpa_11
  ip address 10.3.19.22
  keepalive type http
  port 8003
  active
service Erpaa_22
  ip address 10.3.19.23
  keepalive type http
  port 8003
  active
!*************************** OWNER ***************************
owner IAT
  content Banner-Apps1
    vip address 10.3.20.101
    add service Banner-Apps-1a
    port 7777
    protocol tcp
    advanced-balance sticky-srcip-dstport
    active
  content Banner-Apps2
    add service Banner-Apps-1b
    add service Banner-Apps-2b
    port 7777
    protocol tcp
    url "/*"
    active
  content Erp_IAT
    vip address 10.3.20.230
    add service Erpa_11
    add service Erpaa_22
    port 8003
    protocol tcp
    url "/*"
    active
!*************************** GROUP ***************************
group Banner-Apps-Grp
  active
group ERP-Apps-Grp
  add service Erpa_11
  active
       Any Help is much Appreciated
Sandeep
Hi Sandeep,
Please go through this link and let me know if you have any questions. It explains beautifully about configuring HTTP keepalives.
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a008009452c.shtml
Kanwal
6 Replies 6
Kanwaljeet Singh
Hi Sandeep,
You have configured a group for these services (oracle) but do you really need it? This is needed for server originating connections which will be natted with the VIP. Secondly you have configured URL "/" in content rule which makes it a L5 rule which means that CSS will open a different connection at the backend since it needs to examine the HTTP GET REQUEST.
Are you able to ping the services from CSS itself when your VIP is not pingable? What is the status of services in CSS during the problem? From where are pinging the VIP? Is client in same as server subnet?
Configuration looks fine but we need to check what is exactly being done.
Kanwal
Hi Kanwal
Thank you for the reply.
I agree with you that group doesnt need to be created as i dont think there will be any connections origination from server. It will all be client requests from load balancer ip .
I was not sure about url .. but as you pointed out, i can ping physical ip address of the actual hosts when the virtual ip is not pingable.. but i cannot telnet to port 8003 on the physical hosts .
When i change keepalive to icmp , the virtual ip 10.3.20.230 is pingable , but when i keep it as http, the virtual ip stops pinging.
As you pointed , it seems that it is http configuration that seems the issue with keealive.
I will get the application guy to make the services up in the phyiscal hosts and then ask him to provide me with url for http .
One question , lets says he gives me the  url http:erpmycompany.abc.ae:8003, how should i configure the service with this url for http.
Sandeep
Hi Sandeep,
Do you mean to ask how should you configure keepalive for that URL? You will have to use HTTP keepalive.
Kanwal
Hi Kanwal
Should i just mention like before keepalive type http or can i explicitly mention the url in the keepalive type http command. the syntax i mean.
Sandeep
Hi Sandeep,
Kanwal
sandeep.menon
Hi Kanwal
Thank you for your kind assistance.
I will review the document. I am sure it will helpful.
Thank you again for your valuable time .
Sandeep
