Cisco 6500 X6066 CSM Module Reporting
CSCO11177789
Hi;
Is there any tool for reporting on csm module reals/vservers etc. connections between given time periods ?
If not , may i export these values with any commands from cli ?
Umut
Kanwaljeet Singh
You can use any SNMP tool to monitor CSM using SNMP MIBS.The Cisco CSM supports two Read Only MIBs: CISCO-SLB-MIB and CISCO-SLB-EXT-MIB, which are available at  ftp://ftp.cisco.com/pub/mibs/.
Traps can be sent based on real server, virtual server, and fault tolerant state changes. This is an old product and not much options are available SNMP wise.
While searching more related to this TOPIC i found a similar discussion. Kindly go through it and see if it helps you.
https://supportforums.cisco.com/thread/2024621
The CSM also allows you to confiure TCP scripts for HM and other particular tasks. Please have a look at the link below for details regarding the scripts:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/3.2/configuration/guide/scriptg.html
Kanwal
Thank you for your reply.
I think we need to change load balancer infrastructure asap.
Yeah they have been end of life for a while now and end of software engg support too.
Kanwal
