Cisco ACE 4710 Connection Figures skewed
Brian O'Flynn
   I am doing some fairly basic loadbalancing with sticky connections based on source IP.  If I do a show Serverfarm XXX command I can see 80 connections going to one server and 890 going to another.
Now if I do a show conn rserver XXX-1 serverfarm XXX | count
show conn rserver XXX-2 serverfarm XXX | count
I can see 165 connections going to the first server and only 9 going to the second.
This sounds about right for the first server considering the in and out connections.  But the second server has me confused with the number showing.  I have tried the clear conn for that rserver but the figure seems to hover around 890 - 900.  Load balancing is Round Robin at the moment.
The second server is functioning ok as I can access it when bypassing the loadbalancer.
We have rebooted the second server and even when the probe-failed status was showing for the server, the current connections from the Show Serverfarm XXX command still showed around the 890 mark.
Has anybody seen this before and know of a way to reset this counter?
Cheers
Brian
Gilles Dufour
we had several issues in the past with the count of active connections in 'show serverfarm'.
Could you test the latest version and if the problem persists open a service request with the TAC to report the problem so we can fix it.
Thanks.
Gilles
Gilles Dufour
Thanks.
Gilles
Thanks Giles, it is good to know I wasn't going crazy looking at those figures.  Will plan the upgrade.
Cheers
Brian
