cisco ace bridge mode
susim
Level 3
Level 3
What is the differnece between bridge mode and one arm mode deployment
Kanwaljeet Singh
-=Routed Mode=-
-VLANs can be shared between contexts.
-Servers behind ACE use ACE as a gateway.  That means that you have to change the subnet/gateway on your server to point directly to ACE and create a new IP subnet on the server/ACE. (note that the server would not have to be L2 adjacent necessarily, but you will need to create 2 subnets on ACE and the server should be behind one of them in a manner where all traffic to/from the server only traverses that path.  If the routing behind the server has a path around the ACE, you will have to use source NAT or PBR to make sure loadbalanced flows are symetric.)
-Non-loadbalanced flows can be NATted
-Access to the servers chagnes because of the new subnet.  You can configure static NAT on ace to reach the servers via the old IP's if needed - or update the routing within the network to reach the servers through ACE.
ONE ARM mode is still routed mode but you have vip and server's are in the same vlan.
-=Bridged Mode=-
-VLANs that are bridged can not be shared between contexts.
-Servers behind ACE use the same gateway as previously.  The only change to the existing topology is L2 VLANs.  You will put your servers on a new L2 vlan behind ACE. ACE will bridge the new VLAN with the existing VLAN to allow traffic flow.
-Non-loadbalanced flows can not be NATted. (this is probably the only real limitiation between bridged and routed.)
-Clients can access the servers directly, the same as before the change, no special routing/natting will need to be done.
Kanwal
Note: Please mark answers if they are helpful.
Suppose the server  in vlan 10 (layer 3 ) and  vlan  11 (layer2 ) ,Can i assign the  vlan i 10 instead of l2 vlan in bridged mode . Does it make any difference ?
I am not sure i get the question. But you put ACE in existing L2 path and create another vlan on ace and ace bridges the two.
Share your existing technology and requirement in detail please.
Kanwal
