Cisco ACE - CLSRST connection state
cisco_lite
hi,
During performance testing with IBM Rational Performance Tester tool with 500 users, I noticed above 4000 connections in 'show conn' display and most of the connection states showed as 'CLSRST'.
On doing search the meaning I found is
'CLSRST-ACE closed the connection by resetting it'
What does it mean and is it normal to see so many CLSRST connections.
Thanks.
It looks as if you are hitting CSCsw83500.
Syed Iftekhar Ahmed
