Cisco ACE VIP not responding to Pings
axiasupport
I've searched.....  I cannot figure out why my VIPs do not ping.  I have two vlans that both replay to a ping on the interface IPs.  And I'm new at this, thanks in advace.
GKEL2-ACE1/35568059-Axia# show run
Generating configuration....
no ft auto-sync startup-config
logging enable
logging timestamp
logging trap 5
logging host 10.85.242.100 udp/514
login timeout 60
crypto chaingroup walnut-wcrt100
  cert .dom.cer
  cert wcrt100.pem
crypto chaingroup .dom-wcrt100
  cert .dom.cer
  cert wcrt100.pem
crypto csr-params .dom
  country CA
  state AB
  organization-unit IT
  common-name .dom
  serial-number 1000
  email support
  country CA
  state AB
  common-name .dom
  serial-number 1001
  email support
access-list ANYONE line 10 extended permit ip any any
access-list ANYONE line 20 extended permit icmp any any
access-list All line 1 extended permit ip any any
probe http HTTP1025
  port 1025
  interval 2
  faildetect 2
  passdetect interval 2
  request method get url /Login.css
  open 1
probe icmp PING
  interval 2
  faildetect 2
  passdetect interval 60
probe tcp PROBE-TCP
  interval 2
  faildetect 2
  passdetect interval 10
  passdetect count 2
  open 1
rserver redirect REDIRECT-HTTPS
  webhost-redirection https://%h%p 302
  inservice
rserver host WL1
  ip address 10.205.70.100
  inservice
rserver host WL2
  ip address 10.205.70.101
  inservice
rserver host WLDev1
  ip address 10.205.71.202
  inservice
rserver host WLDev2
  ip address 10.205.71.203
  inservice
rserver host WLTest1
  ip address 10.205.71.150
  inservice
rserver host WLTest2
  ip address 10.205.71.151
  inservice
serverfarm redirect REDIRECT-SERVERFARM
  rserver REDIRECT-HTTPS
    inservice
serverfarm host WEBLOGIC-7433
  predictor leastconns
  probe PING
  rserver WL1 7433
    inservice
  rserver WL2 7433
    inservice
serverfarm host WEBLOGIC-PROD
  probe PING
  rserver WL1 1025
    inservice
  rserver WL2 1026
    inservice
serverfarm host WEBLOGIC-TEST-SSH
  rserver WLTest1 22
    inservice
  rserver WLTest2 22
    inservice
sticky http-cookie acecookie STICKY-INSERT-COOKIE
  cookie insert
  serverfarm WEBLOGIC-PROD
action-list type modify http REWRITE
  header insert response Via header-value "1.1 web:%ps (ace10-8/a2)value"
  header insert request Via header-value "1.1 web:%ps (ace10-8/a2)value"
  header insert request X-Forwarded-Proto header-value "%pd"
  ssl url rewrite location "*.*"
  ssl header-insert session Id
ssl-proxy service ssl-client
ssl-proxy service ssl-proxy
  key netcracker.cal.dom.key
  cert netcracker.cal.dom.cer
  chaingroup netcracker.cal.dom-wcrt100
class-map match-any L4VIPCLASS
  2 match virtual-address 10.205.70.80 any
class-map type http loadbalance match-any L7-URL
  2 match http url /*.*
class-map type http loadbalance match-all L7SLBCLASS
  2 match http url /*
class-map type management match-any REMOTE-MANAGEMENT
  2 match protocol telnet any
  3 match protocol icmp any
  4 match protocol ssh any
  5 match protocol snmp any
  6 match protocol http any
  7 match protocol https any
class-map match-any SSH_Test
  2 match virtual-address 10.205.71.80 tcp eq 22
class-map match-any weblogic-7433
  2 match virtual-address 10.205.70.80 tcp eq 7433
class-map match-any weblogic-http
  2 match virtual-address 10.205.70.80 tcp eq www
class-map match-any weblogic-https
  2 match virtual-address 10.205.70.80 tcp eq https
policy-map type management first-match REMOTE-MANAGEMENT
  class REMOTE-MANAGEMENT
    permit
policy-map type loadbalance first-match L7SLBPOLICY
  class L7SLBCLASS
    ssl-proxy client ssl-client
policy-map type loadbalance first-match SSH_Test_Policy
  class class-default
    serverfarm WEBLOGIC-TEST-SSH
policy-map type loadbalance first-match weblogic-7433-policy
  class class-default
    serverfarm WEBLOGIC-7433
policy-map type loadbalance first-match weblogic-http-policy
  class class-default
    serverfarm REDIRECT-SERVERFARM
policy-map type loadbalance first-match weblogic-https-policy
  class L7-URL
    sticky-serverfarm STICKY-INSERT-COOKIE
  class class-default
    action REWRITE
    ssl-proxy client ssl-proxy
policy-map multi-match L4LSBPOLICY
  class L4VIPCLASS
    loadbalance policy L7SLBPOLICY
policy-map multi-match LB-VIP
  class weblogic-http
    loadbalance vip inservice
    loadbalance policy weblogic-http-policy
    loadbalance vip icmp-reply
    nat dynamic 1 vlan 3440
  class weblogic-https
    loadbalance policy weblogic-https-policy
    ssl-proxy server ssl-proxy
  class weblogic-7433
    loadbalance policy weblogic-7433-policy
policy-map multi-match LB-VIP-Test
  class SSH_Test
    loadbalance policy SSH_Test_Policy
interface vlan 3440
  description Internal Production
  ip address 10.205.70.250 255.255.255.0
  access-group input All
  access-group output All
  nat-pool 1 10.205.70.249 10.205.70.249 netmask 255.255.255.0 pat
  service-policy input REMOTE-MANAGEMENT
  service-policy input LB-VIP
  service-policy input L4LSBPOLICY
  no shutdown
interface vlan 3516
  description Internal Test/Dev
  ip address 10.205.71.250 255.255.255.0
  nat-pool 2 10.205.71.249 10.205.71.249 netmask 255.255.255.0 pat
  service-policy input LB-VIP-Test
  no shutdown
interface vlan 3520
  description LB
  ip address 10.205.72.1 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.205.70.253
username admin password 5 $1$r2r0NmEH$z8S0RxYdhwOE4RGXQ41  role Admin domain default-domain
username cust_admin password 5 $1$/tOIIfUK$yigE519cqLq1IFgX.  role Admin domain default-domain
8 Replies 8
Kanwaljeet Singh
Hi Axia,
Is it only ping which is not working or everything directed at VIP's doesn't work? If  it is ping did you check if it allowed on FW etc?
Can you do "show service-policy summary"? Can you see if VIP is in-service or out of service?
Are you able to ping it from same subnet or switch ? You have configured loadbalance vip icmp reply so it should reply to ICMP requests even if serverfarm is down.
Kanwal
I have added two more VIPs since yesterday and they respond to to pings properly.  The VIPs all work fine just no pings to 10.205.70.80.  Thanks
GKEL2-ACE1/35568059-Axia# show service-policy summary
service-policy: L4LSBPOLICY
Class                            VIP             Prot  Port        VLAN          State    Curr Conns   Hit Count  Conns Drop
L4VIPCLASS                       10.205.70.80    any   any         1,3440,3516
                                 10.205.71.80    any   any         1,3440,3516
                                 10.205.71.90    any   any         1,3440,3516
        OUT-SRVC          0        1080         45
service-policy: LB-VIP
weblogic-http                    10.205.70.80    tcp   eq 80       1,3440        IN-SRVC           0       50739         53
weblogic-https                   10.205.70.80    tcp   eq 443      1,3440        IN-SRVC           0        7384        112
weblogic-7433                    10.205.70.80    tcp   eq 7433     1,3440        IN-SRVC           0      145306         30
service-policy: LB-VIP-Dev
weblogic-http-dev                10.205.71.90    tcp   eq 80       1,3516        IN-SRVC           0           0          0
weblogic-https-dev               10.205.71.90    tcp   eq 443      1,3516        IN-SRVC           0           0          0
weblogic-7433-dev                10.205.71.90    tcp   eq 7433     1,3516        IN-SRVC           0           0          0
service-policy: LB-VIP-Test
SSH_Test                         10.205.71.80    tcp   eq 22       1,3516        IN-SRVC           0          28         24
weblogic-http-test               10.205.71.80    tcp   eq 80       1,3516        IN-SRVC           0          96         40
weblogic-https-test              10.205.71.80    tcp   eq 443      1,3516        IN-SRVC           0         135         61
weblogic-7433-test               10.205.71.80    tcp   eq 7433     1,3516        IN-SRVC           0          27         11
Hi Axia,
Ok. Here's the configuration:
class L4VIPCLASS
You are missing "loadbalance vip inservice" and "loadbalance vip icmp reply". Please apply these commands and that should resolve the issue. You can see in above output it is OUT-SRVC
Kanwal
  class L4VIPCLASS
This policy-map isn't really in use  I added the lines you mentioned but no effect.
Hi Axia,
Could you check if it is OUT-SRVC or IN-SRVC now?
show service-policy L4LSBPOLICY summary.
Can you try a different IP for VIP?
Kanwal
I have removed that service policy completely.  It was from some knowledgebase article when I was trying to get http redirection working.
There is no more L4LSBPOLICY nor L4VIPCLASS, Thanks a lot for looking at this...
weblogic-http                    10.205.70.80    tcp   eq 80       1,3440        IN-SRVC           0       50773         53
weblogic-https                   10.205.70.80    tcp   eq 443      1,3440        IN-SRVC           0        7406        112
weblogic-7433                    10.205.70.80    tcp   eq 7433     1,3440        IN-SRVC           0      145321         30
SSH_Test                         10.205.71.80    tcp   eq 22       1,3516        IN-SRVC           0          29         24
weblogic-http-test               10.205.71.80    tcp   eq 80       1,3516        IN-SRVC           0         117         40
weblogic-https-test              10.205.71.80    tcp   eq 443      1,3516        IN-SRVC           0         161         61
  2 match http url /*
class-map match-any weblogic-7433-dev
  2 match virtual-address 10.205.71.90 tcp eq 7433
class-map match-any weblogic-7433-test
  2 match virtual-address 10.205.71.80 tcp eq 7433
class-map match-any weblogic-http-dev
  2 match virtual-address 10.205.71.90 tcp eq www
class-map match-any weblogic-http-test
  2 match virtual-address 10.205.71.80 tcp eq www
class-map match-any weblogic-https-dev
  2 match virtual-address 10.205.71.90 tcp eq https
class-map match-any weblogic-https-test
  2 match virtual-address 10.205.71.80 tcp eq https
    permit
  class L7SLBCLASS
  class class-default
policy-map type loadbalance first-match weblogic-7433-dev-policy
  class class-default
    serverfarm WEBLOGIC-7433-Dev
  class class-default
policy-map type loadbalance first-match weblogic-7433-test-policy
  class class-default
    serverfarm WEBLOGIC-7433-Test
policy-map type loadbalance first-match weblogic-http-dev-policy
  class class-default
  class class-default
policy-map type loadbalance first-match weblogic-http-test-policy
  class class-default
policy-map type loadbalance first-match weblogic-https-dev-policy
  class L7-URL
    sticky-serverfarm STICKY-INSERT-COOKIE-DEV
  class class-default
    serverfarm WEBLOGIC-DEV
    action REWRITE
  class L7-URL
  class class-default
    action REWRITE
policy-map type loadbalance first-match weblogic-https-test-policy
  class L7-URL
    sticky-serverfarm STICKY-INSERT-COOKIE-TEST
  class class-default
    action REWRITE
    ssl-proxy client ssl-proxy-nctest
  class weblogic-http
    loadbalance vip icmp-reply active
  class weblogic-7433
policy-map multi-match LB-VIP-Dev
  class weblogic-http-dev
    loadbalance policy weblogic-http-dev-policy
    nat dynamic 1 vlan 3516
  class weblogic-https-dev
    loadbalance policy weblogic-https-dev-policy
  class weblogic-7433-dev
    loadbalance policy weblogic-7433-dev-policy
  class SSH_Test
  class weblogic-http-test
    loadbalance policy weblogic-http-test-policy
  class weblogic-https-test
    loadbalance policy weblogic-https-test-policy
    ssl-proxy server ssl-proxy-nctest
  class weblogic-7433-test
    loadbalance policy weblogic-7433-test-policy
interface vlan 3440
  mac-sticky enable
  no shutdown
interface vlan 3516
  mac-sticky enable
  nat-pool 1 10.205.71.240 10.205.71.249 netmask 255.255.255.0 pat
  service-policy input LB-VIP-Dev
  no shutdown
interface vlan 3520
  description LB
  no shutdown
I added an IP to this one policy and it Pings properly.  but still not .80
  3 match virtual-address 10.205.70.81 tcp eq 7433
Hi Axia,
Let us concentrate on one.
class class-default
class weblogic-http
interface vlan 3440
mac-sticky enable
no shutdown
Can you tell me what is the status of serverfarm here? You have loadbalance vip icmp-reply active which means that rserver in serverfarm should be active for VIP to reply to ping. If you just configure loadbalance vip icmp-reply, it will ignore serverfarm status and reply to ping. Can you check on that?
Kanwal
