Cisco ACE with F5 ASM
chenyokechuan
Hi All,
How can i divert traffic to F5 ASM (Web Application Firewall) before reach the real server?
access-list ANYONE line 8 extended permit ip any any
probe icmp ICMP
  interval 2
  faildetect 4
  passdetect interval 4
  passdetect count 4
probe tcp TCP_80
  interval 2
  faildetect 4
  passdetect count 4
rserver host F5_ASM_01
  ip address 10.25.245.4
  inservice
rserver host SSCP_01
  ip address 10.26.74.21
  inservice
rserver host SSCP_02
  ip address 10.26.74.22
  inservice
serverfarm host F5_ASM
  transparent
  failaction purge
  predictor hash address source
  probe ICMP
  rserver F5_ASM_01
    inservice
serverfarm host Web_farm
  failaction purge
  probe TCP_80
  rserver SSCP_01
    inservice
  rserver SSCP_02
    inservice
class-map match-all F5_VIP
  2 match virtual-address 10.25.245.1 tcp eq www
class-map type management match-any Mgmt_class
  2 match protocol icmp any
  3 match protocol snmp any
  4 match protocol telnet any
  5 match protocol ssh any
class-map match-all Web_80_class
  2 match virtual-address 172.20.133.100 tcp eq www
policy-map type management first-match Mgmt_policy
  class Mgmt_class
    permit
policy-map type loadbalance first-match F5_ASM_policy
  class class-default
    serverfarm F5_ASM backup Web_farm
policy-map type loadbalance first-match Web_policy
  class class-default
    serverfarm Web_farm
policy-map multi-match Accel_SLB_policy
  class Web_80_class
    loadbalance vip inservice
    loadbalance policy F5_ASM_policy
    loadbalance vip icmp-reply active
policy-map multi-match Web_SLB_policy
  class F5_VIP
    loadbalance policy Web_policy
service-policy input Mgmt_policy
access-group input ANYONE
interface vlan 271
  description ### Client side ###
  ip address 172.20.133.27 255.255.255.0
  no normalization
  mac-sticky enable
  service-policy input Accel_SLB_policy
  no shutdown
interface vlan 281
  description ### F5 ASM side ###
  ip address 10.25.245.10 255.255.255.0
  no normalization
  mac-sticky enable
  service-policy input Web_SLB_policy
  no shutdown
interface vlan 291
  description ### Server side ###
  ip address 10.26.74.2 255.255.255.0
  no normalization
  mac-sticky enable
  no shutdown
DR-ACE-01/PORTAL-TIER1#
DR-ACE-01/PORTAL-TIER1# sh conn address 172.20.133.88 netmask 255.255.255.255
conn-id    np dir proto vlan source                destination           state
36750      1  in  TCP   271  172.20.133.88:61234   172.20.133.100:80     ESTAB
35100      1  out TCP   281  172.20.133.100:80     172.20.133.88:61234   ESTAB
Missing  in TCP 281 to out TCP 291....
F5 ASM point 10.25.245.1 (ACE VIP) as gateway.
Please help.
YokeChuan
5 Replies 5
ajayku2
I would suggest to pass the traffic to F5 first and then to ACE. Why would you need to pass traffic from ACE twice.
So I would suggest this way :
Client traffic on VLAN 10 >> Web application firewall VLAN 10  >>>> screens the traffic >>>> Pass it to Vlan 11
>>> VLAN 11 is forwarded to ACE >>> ACE load balance the traffic >>>> Pass it to vlan 12 ( server vlan)
regards,
Ajay Kumar
Hi Ajay,
Thanks for the reply and suggestion.
Current client production network, ACE are perform VIP loadbalance for existing server farm.
Client don't plan to modify current network setup. That why F5 ASM are setup to attach with ACE.
Are ACE able to handle this kind setup? (traffic pass ACE twice)
YokeChuan
Hi Yoke,
It is possible. You just have to create two ACE context.
ACE context 1 --    Vlan 10 ( Client )  ----  Vlan 11 ( Web app firewall )
ACE context 2 -- VLAN 12 ( Web app firewall traffic ) --- Vlan 13 ( Serverfarm)
Also read the following :
By default, the ACE does not allow traffic from one context to another  context over a transparent firewall. The ACE assumes that VLANs in  different contexts are in different Layer 2 domains, unless it is a  shared VLAN. The ACE allocates the same MAC address to the VLANs.
When you are using a firewall service module (FWSM) to bridge traffic  between two contexts on the ACE, you must assign two Layer 3 VLANs to  the same bridge domain. To support this configuration, these VLAN  interfaces require different MAC addresses.
To enable the autogeneration of a MAC address on a VLAN interface, use the mac address autogenerate command in interface configuration mode. The syntax of this command is as follows:
regards,
Ajay Kumar
Hi Ajay,
Thanks for the reply.
I have create 2 context as suggested, but i still confuse on WAF routing.
Below are configuration file for Portal-Teir1 and Web-Server context.
DR-ACE-01/PORTAL-TIER1# sh run
Generating configuration....
probe icmp ICMP
  interval 2
  faildetect 4
  passdetect count 4
  inservice
  transparent
  failaction purge
  probe ICMP
  rserver F5_ASM_01
    inservice
  class Mgmt_class
    permit
  class class-default
    serverfarm F5_ASM
  class Web_80_class
interface vlan 271
  no normalization
  mac-sticky enable
  no shutdown
interface vlan 281
  no normalization
  mac-sticky enable
  mac-address autogenerate
  no shutdown
DR-ACE-01/WEB-Server# sh run
probe tcp TCP_80
  interval 2
  faildetect 4
  passdetect count 4
  inservice
  inservice
  failaction purge
  probe TCP_80
  rserver SSCP_01
    inservice
  rserver SSCP_02
    inservice
  2 match virtual-address 10.26.75.100 tcp eq www
  class Mgmt_class
    permit
  class class-default
    serverfarm Web_farm
  class Web_80_class
interface vlan 291
  no normalization
  no shutdown
interface vlan 292
  ip address 10.26.75.2 255.255.255.0
  no normalization
  mac-sticky enable
  no shutdown
Do i still need a VIP for VLAN 292?
WAF should route to VLAN 292 VIP or just a normal routing to interface?
Do you have any sample for reference?
Thanks in advanced.
YokeChuan
This should help you. The only thing which is different is you are not doing firewall load balancing. Rest everything will help you to configure in right way.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/slb/guide/fwldbal.html
regards,
Ajay Kumar
