cisco cache engine 550 with L4
f.barook
Is it possible to have a transparent cache in CE-550 with Summit(L4) Switch.with ip spoofing .if yes pls give the details...
Now i have a client which makes a request to Internet cloud through CE-550 , I have configured the L4 to redirect the port 80 request to Cache engine. I have enabled "http L4-switch enable" on CE-550.But now when i make a port 80 request from the client browser i get "Page cannot be displayed", but when i refresh the browser i get the response..plz help me to solve this prob..
didyap
Level 6
Level 6
Try a 'clear cache ' and reboot the cache engine. This should work. If the problem still persists, you would have to check if there are specific issues with the version you are running. It could also be so because the CE has problems to go to the internet and retrieve content on behalf of the users.Maybe there is a problem with DNS resolution or ACL.
You could also check your browser options. If you are using IE, to check yourconnection settings, click the Tools menu, and then click Internet Options. On the Connections tab,click Settings. Check the LAN settings to nsure that the browser is configured to use the Cache engine.( This is in case transparent caching is not working).
On the Cache engine, make sure you have the following lines:
http l4-switch enable
no bypass load enable
For CE version 2.20 and above, the following two lines are sufficient to enable transparent caching.
If the Layer 4 switch supports WCCP, you can configure the Cache Engine for transparent caching using WCCP.
http://www.cisco.com/warp/public/117/cache_engine/transparentconfig.html
