Cisco Catalyst5509 with WS-X5530 SUP engine
Lavanholy
I have a Cisco catalyst 5509 with WS-X5530 sup engine,SUP engine LED is normal (Green glowing continuously) and working fine.
But when I try connecting a console,nothing is displayed onto my screen.I have reseted the switch also but still no display.
Otherwise switch is working fine without any problem,we want to access the switch through console to change the password.We forgot the existing password.
When we try telneting to the switch IP it ask us to enter the password,when we enter the any letter as the password,it close the connection to host,instead of giving us the another try.
Please can anyone give me the remody?
Thanks and Regards,
S.venkataraman.
ebreniz
Level 6
Level 6
Check the hyperterminal settings,
bits per second: 2400
Data bits : 8
Parity : none
stop bits:1
Flow control: none
