CISCO CMS HTTP and HTTPS Sticky
pedronovais
Community Member
We have a CISCO CMS and we have configured it to load balance some webs pages that can be reached with HTTP and HTTPS with Sticky session.
The problem we are facing is that once a computer is connected using a protocol we cannot change,
t0 - PC1 establishes connection using HTTP - Success
t0 - PC2 establishes connection using HTTPS -Success
t1 - PC1 -tries to establish connection using HTTPS - Failed
t1 - PC2 -tries to establish connection using HTTP - Failed
so once a PC establishes a connection using a protocol it is bounded to it. Both protocols are working simultaneously on the server side but we need to have them on the client side also
Below is the configuration on the CISCO CMS
sticky 30 netmask 255.255.255.240 address source
sticky 20 netmask 255.255.255.255 address source
natpool LB-PGW 172.21.148.20 172.21.148.20 netmask 255.255.255.0
probe SERVICE tcp
interval 3
failed 3
probe 8080 tcp
interval 3
no failed 3
port 8080
serverfarm PGWWEB80
nat server
nat client LB-PGW
real 172.21.148.10 80
  inservice
real 172.21.148.11 80
  inservice
probe SERVICE
vserver PGWWEB80
  virtual 172.21.148.20 tcp 80
  serverfarm PGWWEB80
  sticky 1440 group 30
  persistent rebalance
  inservice
serverfarm PGWWEB8101
nat server
nat client LB-PGW
real 172.21.148.10 8101
  inservice
real 172.21.148.11 8101
  inservice
probe SERVICE
vserver PGWWEB8101
  virtual 172.21.148.20 tcp 8101
  inservice
serverfarm PGWWEB443
nat server
nat client LB-PGW
real 172.21.148.10 443
  inservice
real 172.21.148.11 443
  inservice
probe SERVICE
vserver PGWWEB443
  virtual 172.21.148.20 tcp 443
  inservice
Appreciate if someone can provide so help on this subject.
pablo.nxh
Level 8
Level 8
Hello Pedro,
The problem description is a little bit confusing but if I got it right when I client connects to the HTTP VIP then it cannot send a new fresh request over HTTPS to the same VIP.
Your problem may be related to the sticky groups... it is not recommended to have the same sticky group attached to different servers that are serving requests on different ports; this is only used for some e-commerce sites and in that case you use the shared sticky group number 0.
Also can you make the sticky groups a 32 bit mask instead of 28?
Modify your sticky group #30
sticky 30 netmask 255.255.255.255 address source
Create a new sticky group # 40
sticky 40 netmask 255.255.255.255 address source
Associate sticky group 30 with HTTP vserver and 40 to HTTPS.
__ __
Pablo
Pablo is correct here.
Since you do not need to do port redirection because it appears you want the traffic to go to the servers on the same port that they hit on the vserver you should configure the 3 vservers to use a comman servefarm without port redirection as in:
serverfarm PGWWEB80
nat server
nat client LB-PGW
real 172.21.148.10
  inservice
real 172.21.148.11
  inservice
probe SERVICE
then you would use this serverfarm in all 3 vservers and can use the same sticky group.
