Cisco CSM: Duplication of udp packets possible instead of load balancing?
Hi all,
Does anybody know if it's possible to use the csm (WS-X6066-SLB-APC, OS 4.3.1) to duplicate udp packets to several real servers instead of balancing them.
In our special case we want to test duplicating snmp traps to several network management systems whereas on the snmp clients only one target address (the vserver address) is configured.
Many thanks in advance,
Thorsten
Daniel Arrondo Ostiz
Hi Thorsten,
I'm afraid this is not possible. With the CSM you can only load-balance.
Daniel
