Cisco CSR1000v in Azure is not geting more than 100K throughput
Hi, I have set up a Cisco CSR1000v router in the Azure cloud in West Europe with DMVPN. Everything is working but I'v tried to install a few demo licenses with more throughput but it seems it only allows 100kbps bandwith. First I tried th ax_2500M, then I tried appx_5000M but it broke my DMVPN setup. Then I tried sec_5000M but it is the same only 100k bandwith.
this is the version I'm currently running
Cisco IOS XE Software, Version 16.04.01
Cisco IOS Software [Everest], CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.4.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 30-Nov-16 22:13 by mcpre
I also tried to lower the throughput with this command
platform hardware throughput level 250M
#sh platform hardware throughput level
The current throughput level is 250000 kb/s
But it is the same only 100kbps
Does anybody have a fix for this?
Anybody ??
Share the below output.
show version
show license details
show platform hardware throughput level
